C.A.R.B. (California Air Resources Board) Intake
I just moved from AZ to CA and I have to get my car registered, so I took it to an inspection and smog station.......... and failed.
I purchased my Z with a no-name cold air intake already installed, so I cleaned the filter and that was that. AZ doesn't shove their nose up your a$$ for every little thing you do to your car, so I never worried about it.
Apparently you have to have a CARB certified intake in California to be able to pass smog inspection. Well I don't have the special little sticker that means nothing more than the fact that the company that made the intake paid California to allow them to pass here. Because we all know that a cold air intake is nothing more than a freakin' piece of tubing and a basic cone filter, except a CARB certified one is made with ridiculous amounts of engineering and jam pack stuffed with magic pixie dust so that it won't affect the air quality out here, even though it has nothing to do with the exhaust portion of the car
I'm annoyed.
Regardless... I have to figure out what to do. I can replace the whole unit with a CARB certified one (I think I'm looking at $180). Or I can buy or borrow an original intake for inspection and then put my CAI back on afterwards. I really don't want to spend any money right now though. This move killed me financially and I'm not back to good quite yet.
What would you guys recommend?
I'm annoyed.
Pics of intake?
Most likely if it's a no-name intake you would be better off with the OEM intake so you should just find one locally and swap it out to pass CARB and use it going forward
I took this pic the day I got the car, so don't judge the dirt! lol!
I was thinking about getting a Jim Wolf Pop Charger (since it has the CARB sticker) and installing it onto the aluminum tube I have now. I don't know if they would work well together well though.
i know newer injen cold air intakes have a c.a.r.b sticker. im assuming a lot of the main name brand intakes have them also. intakes are usually pretty similar in design, i think they will all get a c.a.r.b. cert. sticker if they apply. exhaust too, i dont see how a cat back system could affect emissions.
The Stillen intake is also C.A.R.B. certified.
If you like your current intake just find a stock intake in the classifieds section and swap before your smog test. To save you some time and aggravation, I'd look for a stock Z-tube too. A picky tech will fail you on the aluminum tube. Basically, any changes from the air filter to the cats have to be stock or C.A.R.B. certified.
In California, your will be ok with a Cat-back system.
Ugh, Cali smog tests one of the few things I hate about Cali, that and the lack of 93 octane haha. Good luck man.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
