Invidia N1 exhaust
Old Nov 9, 2015 | 06:02 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Get a real resonator welded in... It will make you not hate your car.
https://www.z1motorsports.com/exhaus...or-p-4016.html
Old Nov 9, 2015 | 06:11 PM
joonvang's Avatar
joonvang
Sounds like a lot of work and money and time
Old Nov 9, 2015 | 06:12 PM
joonvang's Avatar
joonvang
Originally Posted by travlee
if you have HFC now, prob not
But one wI'll solve the problem right?
Old Nov 9, 2015 | 06:18 PM
travlee's Avatar
travlee
Master
wait....what?!?! if you have high flow cats now, it will not get any quieter
Old Nov 9, 2015 | 06:37 PM
joonvang's Avatar
joonvang
Nah its stock except for the n1 exhaust. Misread your comment. I read somewhere that hfc will quiet the drone inside the cabin down. Guess not
Old Nov 9, 2015 | 06:39 PM
travlee's Avatar
travlee
Master
no, HFC will make it worse since it is more free flowing.
Old Nov 9, 2015 | 06:46 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
High flow cats may help with rasp by helping smooth the sound waves exiting the engine that are stacking up against one another. Very different acoustic problem from drone which has more to do with resonant frequency.
May help reduce some drone but more likely, will just shift the rpm point at which it drones.
Mic
Old Nov 9, 2015 | 06:48 PM
travlee's Avatar
travlee
Master
aka... not really
Old Nov 9, 2015 | 06:51 PM
joonvang's Avatar
joonvang
So there's nothing to help reduce the droning?
Old Nov 9, 2015 | 06:52 PM
travlee's Avatar
travlee
Master
i am done here....
Old Nov 10, 2015 | 02:47 AM
dboyzalter's Avatar
dboyzalter
Or change your exhaust.
Old Nov 10, 2015 | 05:01 AM
joonvang's Avatar
joonvang
I think I will just get the resonator and weld it on. What size would I get though for the invidia n1 exhaust?
They have size 2.5 or 3 inch
Lentgh either 12 inch or 18
Old Nov 10, 2015 | 05:20 AM
travlee's Avatar
travlee
Master
do you do any research on your own?
Old Nov 10, 2015 | 06:38 AM
joonvang's Avatar
joonvang
Tried. No specific result
Old Nov 10, 2015 | 06:50 AM
travlee's Avatar
travlee
Master
the invidia piping is 60mm, 60mm is approx 2.36 inches
Old Nov 10, 2015 | 06:58 AM
dboyzalter's Avatar
dboyzalter
Didnt you just buy it? Why not just return it or call the vender and see what they say.
If not you might want to call an exhaust shop. I had to call 3 different shops before I found one that said they could weld stainless steel, and they still used garbage *** steel mig wire (I should have just did it myself)
But returning it would be your best choice if you can.
One resonator in the non duel part would work wonders though...
Stock exhaust is 2 1/2 inch piping so I would guess you would want the 3 inch resonator if you want it before the split
Old Nov 10, 2015 | 07:08 AM
MicVelo's Avatar
In some other post on rasp, I said the following:
"With this said, the way to reduce or eliminate (hopefully) rasp (Ed. note - new: and possibly drone) from an inexpensive system is to essentially turn it into an expensive system by adding H or X pipes - X-preferred - on a dual system or mid-pipe resonator(s) of specific volume - chamber displacement, not loudness (Vibrant or Magnaflow or.....). Moral of the story: If you don't like/want rasp, figure on spending the dollars up front for an engineered exhaust OR adding to a less expensive one."
Hmmmm.....
The N1 is a single pipe, split dual system using 60mm piping. It already has a mid-pipe resonator so adding a resonator isn't likely to solve your problem because you can't effectively kill/reduce drone without knowing at what particular resonant frequency its reacting and planning out the exhaust chamber volume of the resonator to change said frequency.
You can TRY replacing the existing resonator with something like a Vibrant 1141 ("Ultra Quiet") but in the end, I'd venture that the only way to cure this entirely (and cost effectively) is to replace the entire system with something known to be quieter and nearly-drone-free. (Some examples: S-Tune, Tanabe Medalion Touring, even a dual Gemini or HKS)
I mean, after buying a resonator and having it welded in, you're up to the cost of a Gemini already and you end up with a Frankenstein system. Sell it to someone who doesn't care about the drone and volume. Buyers are out there.
Mic
Old Nov 10, 2015 | 07:33 AM
  #38
joonvang's Avatar
joonvang
Ah man that sucks. I love how it sound like with the silencer, just the drone inside sucks. Yea I probably sell it. Still pretty much brand new. Alright thanks everyone for their input. Appreciated it
Old Nov 10, 2015 | 07:37 AM
  #39
joonvang's Avatar
joonvang
Hmmmm.....
Mic
Call me crazy but wold it be possible to weld on the vibrant resonator along with the one that is already on the exhaust? So two resonator total.
  #40
travlee's Avatar
travlee
Master
why spend money for something that may not work.
