Exhaust Noise Help
Old Apr 18, 2017 | 11:40 AM
350GC's Avatar
350GC
Default Exhaust Noise Help
Hey guys, I need some help with a vibration that is coming from the exhaust on my 07 HR. I have searched the threads and pretty much explored every option that I can find. Hopefully someone can help, I am pretty much at the end of my rope.
Issue is a buzzing/vibration/metal clanging sound when accelerating
Current exhaust setup:
Factory cats > custom 2.5" dual pipes > 2/1 y muffler > 3" single pipe > muffler
Things I have tried:
New muffler
Swapped between high flow cats/factory cats (rattles either way).
Replaced Y-pipe and resonator pipe with new pipes and 2 into 1 muffler at the y.
Removed and/or checked every heat shield or anything else that might be vibrating/buzzing
Checked all clearances underneath, it's not hitting anywhere
Beat on everything with a rubber hammer looking for something loose
Added extra resonator between y and muffler
Notes: Sounds great at idle and when revving it up, only seems to occur when accelerating under load, doesnt seem to matter if you are taking off slow or going hard.
Any help is appreciated!
Old Apr 18, 2017 | 01:29 PM
travlee's Avatar
travlee
Master
nobody will be able to tell you over the internet
