exhaust hanging down to low
Old May 6, 2017 | 06:51 AM
bondyz33's Avatar
bondyz33
Default exhaust hanging down to low
i have just installed megan racing high flow cats and a agency power single exit exhaust y pip back! i have upraged the y pipe to 3inch also! it seems to hang alot lower and i am now scraping over speed bumps! why is it hanging so much lower? many thanks
Old May 6, 2017 | 08:06 AM
dcains's Avatar
dcains
There is always some play in the joints to allow adjustment. So, get back under there, loosen all the connections just enough to allow movement, and get things in proper alignment before tightening all the fasteners again.
Old May 9, 2017 | 07:33 AM
AKS14's Avatar
AKS14
There isnt a ton of room under these cars, especially with 3" piping and being relatively low.
Also some manufacturers will build their exhausts and manufacturing jigs with a relatively loose tolerance/fit against the bottom of the car to avoid possible fitment problems when mix matched with other manufacturers components or just to take into account their own manufacturing tolerances.
Its much easier to hang the exhaust lower and give yourself an extra 3/8" than it is to hold tighter tolerances or deal with customers possibly complaining because their exhaust is hitting the subframe/chassis/etc.
Old May 9, 2017 | 08:29 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Not sure if it even fits this way but could the mid-pipe be upside down creating a weird angle and lower hanging positioning. Memory tells me that's not possible due to the angle to the rear muff junction but.... who's to say? Been a while since I was under there.
Old May 9, 2017 | 09:29 AM
Atreyu'z 350's Avatar
Atreyu'z 350
- Also, when you're ready, you're going to want to tighten the system down from the front -----> back. Just my .
Old May 9, 2017 | 11:58 AM
jdmfetish's Avatar
jdmfetish
WERD!
Old May 14, 2017 | 12:50 AM
bondyz33's Avatar
bondyz33
Thanks people will get under there and try to re adjust
fridaytech21
Aug 14, 2017 12:18 PM
cbax
Jun 3, 2017 03:22 PM
Rickdogg
May 4, 2017 07:40 AM
Zsoldier21
Mar 16, 2017 12:57 PM
