Blue flames
Old Jun 12, 2020 | 07:07 AM
iideadeyeii's Avatar
iideadeyeii
I run NGK coppers now at two steps colder. Copper is the best material plug to run, they just don't last as long
Old Jun 12, 2020 | 08:21 AM
bealljk's Avatar
bealljk
Originally Posted by 03JamesDE
I’m just starting to understand everything and wanting to learn. The Z has a great engine and it’s a great platform to learn on and work on.
Sounds good - nothing wrong with being a beginner and everyone was a beginner at some point in time...
You're best bet will be to read posts on this forum and offer feedback when you are knowledgeable on a subject. If you are don't know the answers to a question or are below the knowledge base of the topic just hang-out and read what others say. As always, stay humble and friendly, and allow yourself to learn. Indeed these are great cars … I've had mine since 2005 and it'll always have a spot in my garage.
Heres some free basic tuning lessons from a trusted source -
https://www.hpacademy.com/courses/ba...ng-fuel-tuning
Old Jun 12, 2020 | 08:29 AM
travlee's Avatar
travlee
Master
and realize that you will only be about 250-260 whp on your car.... you will eventually need a tune, but do all breathing mods you plan on doing before you shell out the money
Old Jun 12, 2020 | 04:46 PM
03JamesDE's Avatar
03JamesDE
Originally Posted by dkmura
If you haven't already purchased your spark plugs, you may want to read this thread. NGK has introduced a new coating for plugs that can be used with the Z:
https://my350z.com/forum/engine-and-...for-the-z.html
The thread lists part numbers and gives a short description on what the new NGKs are like. In short, these plugs will last over 100K and should be installed before you get a tune. One item to check beyond that is the type of fuel injectors being used in your Z. Some people have installed larger injectors with the idea that it'll automatically produce more power. That's not the way it works. Even with the bolt-ons you have, standard OEM fuel injectors are what you should be using.
Thanks for the thread I will definitely read and do more research! I however already bought my spark plugs but that’s okay. I am running everything stock except my exhaust work. I really don’t want to add any engine work until tune or complete rebuild. Will be doing the spark plugs/VC Monday so I will post an update on how my Z is going and if I still have the flames.
Old Jun 12, 2020 | 06:20 PM
DarkZ03's Avatar
DarkZ03
Flames will visually change the way titanium looks so that's probably it. I'll second the coppers being good although I'd rather beef up the ignition and run iridium, I also change my plugs quite frequently. Most racing plugs aren't copper and I believe that has a reason, anyway... check your MAF to make sure it's clean and the air filter as well, keep an eye on oil consumption as that will also cause a rich scenario.
Cspears1411
Sep 30, 2013 10:32 AM
tw8715
Jun 20, 2013 12:06 AM
romnation
Jan 20, 2013 04:06 PM
etl45
Jan 24, 2009 09:04 PM
oman
Jan 14, 2006 11:59 AM
