SSR Engineering Intake Manifold *Pics*
Old Mar 12, 2004 | 05:35 AM
G35SC T.T.'s Avatar
G35SC T.T.
its going on my car, should be on dyno this saturday, so we should have numbers hopefully this weekend.
and the altima made that kind of power with like 5 or 51/2 psi.
changing springs in waste gates right aj.
and he didnt blow that up.
stuff happens in high performance, like motors blowing, etc.
there was other stuff going on with that that people dont know about, and theres no reason to point fingers, tim is a very good guy and knows what he is doing.
Old Mar 12, 2004 | 06:32 AM
Phatmitzu's Avatar
Phatmitzu
Humm...interesting. kinetix now?...or wait for SSR...
Old Mar 12, 2004 | 07:34 AM
SSR Engineering's Avatar
SSR Engineering
Originally posted by teh215
Any idea?
About a week
Old Mar 12, 2004 | 07:46 AM
Sosa's Avatar
Sosa
what's the estimated price?
Old Mar 12, 2004 | 07:48 AM
blubyu's Avatar
blubyu
make something for the VQ35 Maxima. Our intake manifolds breath like **** top end, I wished the 350z manifold would clear the hood on the Maxima. Im at 230whp now but it peaks at 5700 and then falls off. I know it has to do with the VI opening up earlier but the Manifold should breath better high end than it is currently
Old Mar 12, 2004 | 08:20 AM
JeffR116's Avatar
JeffR116
Looks promising. Keep us posted!
Old Mar 12, 2004 | 10:11 AM
350z_taquito's Avatar
350z_taquito
i don't like the design. fuel trim still isn't optimal since the runners are inline then split to feed the opposite banks of the v at the secondary runners (which i'm assuming you'll keep the stock ones). fuel trim would be much better if the runners exited the plenum in 2 adjacent rows of 3, each row feeding the 3 intake ports on each bank.
Old Mar 12, 2004 | 10:18 AM
teh215's Avatar
teh215
If I understand what you are saying, then that would require a new lower manifold as well. This design only replaces the upper manifold.
Old Mar 12, 2004 | 10:20 AM
theZman's Avatar
theZman
I'm not sure I follow. When you say "fuel trim still isn't optimal", what do you mean? Do you mean it won't be base pulse-width? If so, how do you know this?
Old Mar 12, 2004 | 11:07 AM
Ultimateone's Avatar
Ultimateone
any pics installed?
Old Mar 12, 2004 | 11:23 AM
350z_taquito
air flow variance between individual cylinders and the accompanying fuel requirements. you want get as close as possible to equal airflow into each cylinder, and tune each cylinder's injector flow rate accordingly.
Old Mar 12, 2004 | 11:24 AM
350z_taquito
yes, or just incorporate everything into one manifold w/ longer runners.
Old Mar 12, 2004 | 02:12 PM
teh215's Avatar
teh215
Has anyone contacted Hogan Manifolds yet? They do this type of work and they do it well.
Old Mar 16, 2004 | 09:36 AM
dholly's Avatar
dholly
Sorry about the pic quality, but, doesn't this replace both upper and lower intake manifold collector?
Attached Thumbnails SSR Engineering Intake Manifold *Pics*-manifold-connector.jpg
Old Mar 16, 2004 | 01:03 PM
MIAPLAYA's Avatar
MIAPLAYA
"Don't point fingers"? Dude I'm just letting this guy know that there are people on this board that know what happened on other boards for some of their other applications. What happened to the B15 community was not cool. I want to make sure this doesn't happen again here. As for stuff that was happening that no ones knows about..I can find multiple threads where the story changed as to "what happened". Hopefully everything works out here. I know i will not be buying anything from them.
Old Mar 16, 2004 | 02:29 PM
teh215's Avatar
teh215
There is a lower manifold that connect the 2 piece collector to the heads ....
Old Mar 16, 2004 | 03:11 PM
dholly's Avatar
dholly
Right - what the manual refers to as intake manifold. When people use diff terms for the same part my pea brain gets confused. Here's a better pic of the manifold collector.
Attached Thumbnails SSR Engineering Intake Manifold *Pics*-manifold-collector.jpg
Old Mar 16, 2004 | 03:29 PM
  #38
ZU L8R's Avatar
ZU L8R
Viper Sellout
Is there a price estimate?
Old Mar 16, 2004 | 03:41 PM
  #39
PhoenixINX's Avatar
PhoenixINX
lengthen those runners and kiss your topend goodbye.
Fixxxercask
Nov 9, 2015 11:10 AM
