Plenum Leaking?????
Old Sep 3, 2004 | 07:43 AM
maserom's Avatar
maserom
Default Plenum Leaking?????
What is the best way to determine if the plenum is leaking? I installed the Kinetix V4 2 weeks ago and removed it 4 days ago and put back to stock. Ever since the V4 was on and now since the stock one is back on, my MPG is around 11. I dont' hear any air leaks, double checked all hoses, and still i can't figure out why MPG is so down. Should i have put on a new gasket???
I did reset the ECU.
Thanks.
Old Sep 3, 2004 | 07:59 AM
zzzya's Avatar
zzzya
Are you going by what the gauge in the car says or by tracking your mileage and gas consuption? You may need to reset the mpg gauge in the car for it to reset. If you had a plenum leak you should hear it as it would be a fairly loud pssssst on acceleration. Have someone give the car some gas while you listen with the hood up.
Old Sep 3, 2004 | 08:00 AM
ares's Avatar
ares
Veteran
if its back to stock... hmmm
you reset the gauge I assume. try testing it for yourself like zzzya said. have you notice rapid gas use?
Old Sep 3, 2004 | 08:05 AM
murrman100's Avatar
murrman100
Why did you take the v4 off to begin with?
Old Sep 3, 2004 | 09:31 AM
maserom's Avatar
maserom
I have reset the gauge several times. I'm now at 11.9. I can't figure out what the hell is wrong. When putting the new plenum on, i lost a bolt on the back passenger side corner. However, each mechanic i took it to said it was not leaking. I'm getting the new bolt today.
I didn't not like the way the V4 Fit, it was rubbing and causing a vibration in the body. Also, didn't care for the sound it created at all.
Old Sep 3, 2004 | 09:44 AM
murrman100's Avatar
murrman100
The fit sucks.
It really doesn't make that much sound. The you are hearing is it rubbing against the strut bar. Take your strut bar off and the rubbing will go away.
This damn plenum is not worth the problems.
Old Sep 3, 2004 | 11:37 AM
ChrisMCagle's Avatar
ChrisMCagle
You might try spraying some brake cleaner around the perimeter of the plenum while someone revs the engine. If it sputters, then you've got yourself a leak. If not... start looking elsewhere. Are you sure that you have all the hoses connected properly and free from obstructions? How about the hose on the bottom of the Air Intake tube? Is that on properly?
-Chris
Old Sep 3, 2004 | 12:19 PM
MY350Z.COM's Avatar
Originally posted by murrman100
The fit sucks.
THat would destroy the purpose of the Kinetix design.
Old Sep 3, 2004 | 01:26 PM
maserom's Avatar
maserom
I have just checked everyhose and connection over and over and sprayed brake cleaner, no leaks. HOWEVER i think i hear where the hissing sound is coming from...The passenger side Header. I'm nearly positive that that is where the leak is coming from and why my MPG has gone down to 11-12 mpg!!!!!!!!!
ANY THOUGHTS??
Old Sep 3, 2004 | 01:51 PM
ChrisMCagle
ANY THOUGHTS??
No, there is a normal hissing noise that comes from the front of the passenger side. Not sure what causes it, but I hear it on every Z who's hood I stick my head under.
The header is definitely not the problem.
-CHris
Old Sep 3, 2004 | 02:11 PM
maserom's Avatar
maserom
Really!! you may be right, i guess i'm being paranoid! It sounds like it is coming from the passenger side headers up top right:??
Old Sep 3, 2004 | 02:13 PM
murrman100's Avatar
murrman100
Sounds like the vacume hose connection on that side is leaking.
Old Sep 3, 2004 | 02:25 PM
murrman100's Avatar
murrman100
They sure as hell didn't design it for ease of installation.
I wouldn't have minded buying the extended strut bar if I would have known that the damn thing would rub against it.
I had to use 2 1/2 washers on each mount point and tighten up on the strut bar so it would bend out of the way.
I think they just thru the V4 out there to satisfy the people that had cracked v3's without considering fitment issues of the strut bar.
They should have designed it without the grove for the strut bar and like Crawford did, offered a replacment strut bar. Maybe they would have gotten a few more hp from it.
It is good though considering that I get to keep my original plenum instead of being charged a core deposit like Crawford does.
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
