Warranty on Nav door?
Old Apr 18, 2005 | 04:57 PM
Lemans350's Avatar
Lemans350
Default Warranty on Nav door?
After reading dozens and dozens of posts about the Nav door, i was unable to find exactly what i was looking for..
With the 2003 Nav door (no nav system), mine doesnt always open when you push the button, it has to be helped a little by taping it slightly from underneith, it then slides up. It closes just fine.
Anyone had theirs replaced/fixed under warranty or is that just something that has to be lived with on the 03's.
Old Apr 18, 2005 | 05:28 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Everything should be covered under warranty, no matter how little. I would take it to the dealer and tell them you're not satisfied with it's function.
Old Apr 27, 2005 | 07:26 AM
sroks5's Avatar
sroks5
I did....they fixed it and after about a few months it was doing it again. I would like to just take it off and leave it off if possible.
Old Apr 29, 2005 | 03:56 AM
GATORZ's Avatar
GATORZ
My parts for this came in yesterday. The dealer is replacing it on Tuesday. It is covered. I'm sure it will break again in a few months. 03 touring no nav. Wish I could have talked them into the newer one but no go on that. Not even sure it would work.
Dan
Old Apr 29, 2005 | 07:58 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
speaking of nav door, mine broke last week. I have 42k miles, so warranty is out of the question. I disassembled everything and found the door was held by a little plastic hook. The hook broke so I just use epoxy to fix it. it was PITA!! I put some grease on the track and the metal spring, it should be okay for now..
Old Apr 30, 2005 | 02:08 PM
Lemans350's Avatar
Lemans350
Mine isnt bad, it's not worth taking it in at this point i dont think, it does work most of the time. I checked out a brand new 05 35th in the showroom with no nav, and that door didnt work great either, and i dont like how it opens up instead of back. I'm actually glad i have the 03 in this case. Unrelated i still wish there was a way to get ahold of those seatbelt service arm things without buying the whole assy.
Old Apr 30, 2005 | 07:29 PM
Edison_Chen's Avatar
Edison_Chen
2003 w/ Navi...
The door works perfectly
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
