traction controll and speed regulator
Old May 31, 2005 | 11:07 PM
grimace65's Avatar
grimace65
Default traction controll and speed regulator
how do i disable the traction controll? (is it better with the traction controll off?) how do you get rid of the speed limiter, to go past 130mph or wherever the limiter is set at?
Old Jun 1, 2005 | 08:36 PM
JP_WRX's Avatar
JP_WRX
BUMP on this because I have the same question about the TCS. Don't see a button to turn it off...just a VDC button. Help a brutha out so he can do his first rear wheel drive burnout!
Old Jun 1, 2005 | 09:06 PM
Z PHAT Z's Avatar
Z PHAT Z
when you press on the VDC button...and see the VDC light on the dash...that's to turn it off. As for the remove of the speed i'm not sure about it, but the TS or the AAM ECU flash can removes it " I think "
Old Jun 1, 2005 | 09:30 PM
JP_WRX's Avatar
JP_WRX
Yeah, I mentioned that I'm aware of how to turn that off. We asked about how to turn the TCS (traction control) off. Anybody?
Old Jun 1, 2005 | 10:30 PM
NTRIGUE's Avatar
NTRIGUE
I think you misunderstood, the 350Z equipped with VDC is all encompassing Dynamic Stability Control and Traction Control.
On models with VDC the light indicating VDCOFF means no Dynamic Stability Control or Traction Control.
On models without Dynamic Stabilty Control the in-dash lamp indicates TCSOFF.
Old Jun 2, 2005 | 09:26 AM
JP_WRX's Avatar
JP_WRX
Ah, thanks very much xcmpx! I had a feeling that might be the case but just wanted to make sure.
Old Jun 2, 2005 | 09:28 AM
trescincuenta's Avatar
trescincuenta
As far as the speecut goes, the governor from factory I beleive is at 157, do you really need to go that fast?
Old Jun 2, 2005 | 10:45 PM
grimace65's Avatar
grimace65
honestly no, but its just the fact that someone restricts my Z's limitations. i cant stand it.the dealer told me it was set at around 130
Old Jun 23, 2005 | 08:55 AM
drew76924's Avatar
drew76924
i heard from somewere it was 153
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
