electical problem
Old Sep 15, 2005 | 01:16 AM
importfastcarz's Avatar
importfastcarz
Default electical problem
Guys i gotta problem. I just installed a Clarion deck in my Z. Now whenever i turn on my lights the parking lights and tail lights dont work. I cant figure out whats wrong i checked my fuses and there all good.
Old Sep 15, 2005 | 05:38 AM
King Tut's Avatar
King Tut
How did you install it? You did use a wiring harness and didn't cut directly into the OEM wiring right? Anyways since the 350Z has a dimmer wire in the harness I would say that that is the cause as it is there to tell the headunit to dim its lights when you turn on the lights. If that is hooked up improperly something like what you have described could happen.
Old Sep 15, 2005 | 07:04 AM
Fletch69z's Avatar
Fletch69z
That would be my guess too. Trust me, you want to use a harness and hopefully you did. I made the mistake of trying to hardwire my last headunit in my old car and it was a mess, haha.
Old Sep 22, 2005 | 02:38 AM
importfastcarz
yeah i used a harness but it still did not work
Old Sep 22, 2005 | 06:35 PM
Blue 03 Z's Avatar
Blue 03 Z
There is another fuse box up under the cowl mounted to the firewall. So there is a total of three fuse boxes. You have to remove the plastic pieces around the battery to get to it. There are about ten plastic clips. There is a tail fuse in there I bet its blown. The fuse box nissan calls the IPDM.
Old Sep 24, 2005 | 11:36 AM
DIGItonium's Avatar
DIGItonium
Before replacing the fuse, recheck power connections carefully. For some odd reason, I even saw a spark when a ground wire touched a metal clip somewhere behind the dash. It was weird and completely unexpected. Nothing fried though :-)
Otherwise, you might end up blowing the fuse upon insertion. It's like holding a firecracker!
Old Sep 29, 2005 | 02:25 PM
importfastcarz
thanks guys i checkout that 3 fuse box
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
