Stalling leads to New Crank Position Sensor
Old Oct 18, 2005 | 08:53 PM
ringfingur's Avatar
ringfingur
Default Stalling leads to New Crank Position Sensor
Four times in the last week my car has either smoothly stalled out while in upper gears and doing speeds of 40 to 70, or started 'bucking' to the point where I was forced to pull over. Each of these times the engine refuses to start for anywhere from three to five minutes, eventually turning over and allowing me to drive another ten minutes or so without problem. This morning on the way into the dealership however, the Service Engine Soon light was finally thrown, hopefully to my advantage. It seems the source of the recent headaches is due to a faulty Crank Position Sensor that should be on the car in a few days. I just wanted to share some info with you guys in case any of you end up having the same problem. BTW: The car is only 9 months old, its a Base MT with just over 11,000mi. Hope this helps in the future.
Old Oct 20, 2005 | 06:00 PM
chandlerad's Avatar
chandlerad
Default Similar symptoms...same problem?? Hesitation??
My 05 Roadster M/T has exhibited a similar, albeit much milder, symptom over the 18 months and 27K miles that I've driven it. On three occasions I have observed what is best described as a hesitation or stumbling. It occurs after braking to a 3rd or 4th gear downshift followed by maximum throttle. I thought it might have something to do with the traction control system but there was no impending wheel spin. The scary thing is that it hesitates at a time when I'm calling for maximum acceleration. I have not experienced a complete stall or inability to restart. I cannot force it to happen regularly.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
