Door Locks Programmable? Do We Have User Options??
Is the Dealer able to program settings for the locks or alarm based on the owner? I would like to have the Z programmed like my other car was able to be (IS300). When the unlock button is pressed once both doors unlock, when the lock key is pressed the horn does not sound, when the car hit X mph the doors lock, and when the car is shut off and key removed the doors unlock. Are these, or any settings for that matter doable on the Z?
The car, along with the owners manual is in the garage, 9 miles away........or I would of just looked Vs posting!
So now knowing that, would anyone that didnt have a tough day mind letting me if
"When the unlock button is pressed once both doors unlock, when the lock key is pressed the horn does not sound, when the car hit X mph the doors lock, and when the car is shut off and key removed the doors unlock."
are possibleto program? Thanks
I believe you can disable the horn by holding down both the lock and unlock buttons of the remote for a few seconds (near the car of course). Not sure about getting both doors to work together.
I do miss the nice little beep the IS300's do instead of the loud horn honking on the 350Z.
JL
JL
You can change the lock/beep option as described above. It takes two pushes of the remote to open both doors.
As to the rest of the things you asked about, if they are possible they aren't documented.
350Z_Al
Oct 29, 2020 07:44 PM
