What does this mean (!)?
Old Apr 15, 2006 | 11:33 AM
keznevin's Avatar
keznevin
Default What does this mean (!)?
I get this symbol (!) on long trips comes up right above the service engine light. Does anyone know what it its or what it means.
Old Apr 15, 2006 | 11:42 AM
loulinjai's Avatar
loulinjai
e-brake (in canada) just the word "brake" in US
Old Apr 15, 2006 | 12:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's the tire pressure sensor warning light. It says in the owner's manual.
If you have taken off your TPS then you get this light on long drives, it doesn't mean anything.
If you have not taken off your TPS then you probably have low pressure
I think if the weather is cold the light is more likely to come on, but I could be wrong.
Old Apr 27, 2006 | 02:36 PM
Ante Up's Avatar
Ante Up
just to piggy back on this subject, my Z has that same signal too and when i checked the tire pressure all of em are 38 except for the rear top number which is 27. Do you guys know why the tire pressure is so low but kicking the tires and just by looking at it, there are no differences on the 4 tires. Could this just be a problem with my tire monitor?
Old Apr 27, 2006 | 02:41 PM
DavesZ#3's Avatar
DavesZ#3
Kicking the tires and looking at them is not going to tell you that there is a pressure difference. You need to get a good quality tire pressure gauge and use that to check and set the tire pressure.
BTW, the tire pressure warning goes off at 28 psi or lower.
