Need help problem with my windows please
Old Apr 15, 2006 | 03:51 PM
350z0827's Avatar
350z0827
Default Need help problem with my windows please
When I close the passenger window with the auto up it closes and then comes back down like 1/3 the way. also when you open and close the door the window doesn't move up and down like the drivers door window does.
Is there anything I can do for this??
Old Apr 15, 2006 | 07:28 PM
BigD2k5's Avatar
BigD2k5
just take it to the dealer if you still have any warranty. maybe it's a bad window switch or the door ajar switch. have you rolled the window up/down from the pass. side and it still go back down 1/3 of the way? get it fixed ASAP so it doesn't mess up the window from hitting the weather stripping. if not under warranty you might have to swap switches with the driver's side, if compatible, to rule out the switch.
Old Apr 15, 2006 | 07:57 PM
wld350z's Avatar
wld350z
the window motor is out of sync. FRONT DOOR GLASS AND REGULATOR
SETTING AFTER INSTALLATION
Setting of Limit Switch
If any of the following work has been done, set the limit switch (integrated in the motor).
• Removal and installation of regulator.
• Removal and installation of motor from regulator.
Resetting
After installing each component to vehicle, follow the steps below.
1. Raise glass to the top position.
2. While pressing and holding reset switch, lower glass to the bottom position.
3. Release reset switch, and check reset switch returns to the original position, and then raise the glass to the top position.
CAUTION:
Do not operate the glass automatically to raise the glass to the top position.
Do not operate the door switch is turning on.
Old Apr 15, 2006 | 08:01 PM
lex350's Avatar
lex350
^no way..dealer
Old Apr 15, 2006 | 09:34 PM
BigD2k5's Avatar
BigD2k5
Resetting
CAUTION:
That was going to be my next guess.
Old Apr 15, 2006 | 10:23 PM
___DJK___'s Avatar
___DJK___
Those instructions are what the dealer will do if you bring your car there. I just had this done on my Maxima a few weeks ago. Common problem in the Nissan family.
Old Apr 15, 2006 | 10:44 PM
Nexx's Avatar
Nexx
use a hammer, percussive maintainence!
Old Apr 23, 2006 | 07:53 AM
Gering's Avatar
Gering
I had the same problem and Baytown Nissan fixed it for free!!!
Old Apr 23, 2006 | 08:33 AM
Ztalker's Avatar
Ztalker
besides death and taxes...its the Z's power window regulator replacement.
Old Apr 23, 2006 | 08:36 AM
cellphoneguy's Avatar
cellphoneguy
mine are acting screwy too! I have to slam the door so that the dam window will go back up some times. Im at 40,000 miles, you think Nissan will do anything?
Old Sep 26, 2006 | 06:02 AM
kwiker's Avatar
kwiker
Shift_Dorifto
I have 27k on my car but it is past 3yrs...the driver side goes up and then back down a 3rd if i auto roll up, but it is fine if i just hold the switch. Passenger side is skitzo...sometimes it works sometimes it doesn't. If i hold the switch in the first position and open the passenger door sometimes it will roll up...sometimes i have to shut it "firmly"...do you guys think i am out of luck?
Old Sep 26, 2006 | 06:32 AM
Leman'sSunset03's Avatar
Leman'sSunset03
My passenger window did the exact same thing. I would roll it up and then it would come straight back down. I would have to slowly roll it up instead of the auto up feature. It did this until a week ago when I rolled it down and it didn't come back up. Luckily it wasn't raining I took it to Nissan the following day and left it with them and they replaced the window motor. So far everything works like it should, just hope the drivers side doesn't do the same in the future.
Old Sep 28, 2006 | 04:02 PM
dbpoet's Avatar
dbpoet
It will.
Old Sep 28, 2006 | 06:55 PM
Ztalker's Avatar
Ztalker
Originally Posted by dbpoet
It will.
^ i concur.
Old Oct 1, 2006 | 09:25 AM
Blk350Z03's Avatar
Blk350Z03
ditto.
i have 03Z and i cleaned my window motor. it's only gonna be temporary fix. the problem will eventually occur again.
then i would have to replace window motor.
Old Oct 1, 2006 | 10:22 AM
Kabs's Avatar
Kabs
I went to my nissan dealer... they gave me BS that its an ADJUSTMENT.... and that its not covered under warranty.... ADJUSTMENT warranty is only for a year.
Time for me to find another dealer
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
