Different Window Problem (Not Sure If This Is Suppose To Happen)
For some odd reason my passenger side window has this little problem. As you know you can fully lower the windows with the touch of a button, and can close them by pulling the switch to the top (and the windows roll up all the way)
Well when I do this my driver side window rolls all the way up no problem. But my passanger window rolls all the way up..... but then 1 sec later lowers itself like 3-4 inches.... always at the same spot.
Would this be the motor too? Or Something completely different
I dealt with this a few months ago, I actually had to go to the dealer twice for the same window (passenger side) and I know the previous owner had to get the driver side fixed.
The driver side had to have the window regulator reset and I currently have no problems with it. The passenger side, on the other hand, on the first visit, had to get the motor replaced. This was fine for about 2 1/2 months and then the same thing started to happen again.
Went back to the dealer and, like the driver side, the window regulator needed to be reset. All this happen during the factory warrenty period, so luckily, I didn't have to pay a dime.
Besides offical recalls, this is the first time I will EVER suggest this:
Just go to the dealer and they'll straighten things out for you.
Good Luck
Good Luck
