call pulls to the right 350zr - HELP!
Old Apr 18, 2006 | 11:48 PM
MyIS300's Avatar
MyIS300
Default call pulls to the right 350zr - HELP!
I test drove some 2004.5 350z touring today and the car pulled to the right.
This car had 20" wheels on it and it was flush and clean...
What issue could cause the car to pull to the right?
Would a minor alignment fix this?
Does this have anything to do with the feathering issue?
I dont hear any weird noise at low speeds and mine was built on 3/2004
carfax is clean w/ 1 owner and 19k miles...
Any suggestions?
Old Apr 19, 2006 | 04:04 AM
grifferjr's Avatar
grifferjr
pretty normal. especially with those wheels and size tires. just the crown in the road. the early Z's, meaning the 03's had a rod issue on the front causing some pull but every Z, or rather every sports car with the low profile will pull to the right because of the road crown. the wider fatter tires just accentuate it. over the winter i had my narrow snow tires on and no pull. in the last month i put on my 19" rims and the pull to the right is back.
to be sure, take the car to a parking lot, somewhere you know is flat and test there.
Old Apr 19, 2006 | 08:42 AM
MyIS300's Avatar
MyIS300
road crowns differ if your on the right side of the road or left side...
I drove on a completely flat empty parking lot, no crown and it still occured.
Why would it just pull right and not left? High performance sports car my @$$
The size of the wheel shouldn't matter...
the 2004 has the compression rod issue:
http://www.nissanhelp.com/ownership/.../NTB03-046.htm
would one buy 30k+ car knowing of these issues prior to buying their cars?
Anyone?
Old Apr 19, 2006 | 08:45 AM
MyIS300's Avatar
MyIS300
worst part is that this car is a 2004.5 with a build date 3/2004 aka with knee pad
Old Apr 19, 2006 | 09:27 AM
deleted
Old Apr 21, 2006 | 08:47 PM
Question
deleted
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
