Window grease streaks?
Old May 2, 2006 | 03:49 PM
whoopazz1's Avatar
whoopazz1
Default Window grease streaks?
Just wondering if the dealership should fix this problem if my Z is still under warranty, I have grease streaks on both sides, its a 03 with 15100 kms on it.
thx.
Old May 2, 2006 | 04:31 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
search
Old May 2, 2006 | 04:59 PM
RED Z's Avatar
RED Z
i have the same problem and mine is an 03 also... never got them to fix it tho... really a pain but i herd that u can take it out and clean it but that may be trouble in itself...
Old May 2, 2006 | 05:04 PM
Bumble350z's Avatar
Bumble350z
Old May 2, 2006 | 07:52 PM
whoopazz1's Avatar
whoopazz1
I have searched under the Repair topic, but it only hold 3 pages of info, so it didn't find anything.
W/e thx for the info, I'll try and figure it out some other way.
Old May 2, 2006 | 08:01 PM
Mapleleaf's Avatar
Mapleleaf
Sure they would fix it for you ... where do you live East or West?
Old May 3, 2006 | 04:14 AM
grifferjr's Avatar
grifferjr
how bad does it bug you?????
sure it bothers me a little but i carry a microfiber cloth and window cleaning tearoffs in the car and just wipe it down whenever i am at a stop light.
i am sure that by now, the dealers have become readily skilled at fixing this, but i have heard too many horror stories of what happens after taking the door apart, that i consider the streaks the far less of the two evils!!
Old May 3, 2006 | 05:36 AM
Window streaks? This is the first I have heard about it.
Old May 3, 2006 | 08:01 AM
whoopazz1's Avatar
whoopazz1
I live west, thx for all he replies.
Old May 23, 2006 | 09:42 PM
StraySheep's Avatar
StraySheep
Just to let everyone know, the window grease streak still happened to my 2006 coupe.
On the passenger side only, one grease streak at about the center of the glass on the inside.
Old Jun 5, 2007 | 08:57 PM
dkorr's Avatar
dkorr
yup.... that's exactly what i have on my 06 as well... except i have tints so i have to be careful what cleaning product i use to get rid of it
Old Jun 6, 2007 | 05:21 AM
zzz350's Avatar
zzz350
never had the prob on my 03
Old Jun 6, 2007 | 05:28 AM
SirSpeedyZ's Avatar
SirSpeedyZ
i have an extended warranty on my Z, will the dealership fix this for free?
Old Jun 6, 2007 | 05:31 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The dealership should fix this issue for you. Look for the window streak TSB#. Write it down and take it in to them.
Old Jun 6, 2007 | 05:39 AM
Brick-Z's Avatar
Brick-Z
Took mine to the dealership but after a few days the streaks came back. If you do a search there was a write up in regards to removing a piece of greased felt from inside the door panel which guides the window up and down.
Old Jun 6, 2007 | 05:55 AM
THE TECH's Avatar
THE TECH
Start here:
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Old Jun 6, 2007 | 06:07 AM
Demon Z's Avatar
Demon Z
I took my Z to the dealership twice to have this annoying issue rectified, and the problem remains. Nissan super-mystery grease-2, Nissan inept factory-trained techs, 0.
Old Jun 6, 2007 | 01:19 PM
bender's Avatar
bender
It's a sort of like a piece of felt.
If you take it to the dealer, they'll just clean it.
I was tempted to remove it, but it looks like it helps guide the glass plus keep it from possibly hitting the metal arms.
If you want to fix it yourself, just look at the guides for cleaning your window motor. You'll need to take the door panel off, plus the metal panel that holds the glass and motor. It's behind that panel somewhere on the metal arm.
Old Sep 12, 2007 | 10:48 AM
dkorr's Avatar
dkorr
has anyone taken the door off before? i'm hesitant to let the dealer monkey around w/ the door assembly... but the huge streak is an eyesore
Old Sep 12, 2007 | 10:51 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
I'd say just keep cleaning your window. everytime the dealer touches my car they create a whole diff problem.
