Water Leaking from rear window washers
Its getting really annoying, every once and a while water comes out of that little thing on the top of the rear windows that squirts water out. Its a stream that leaves ugly streaks, While I'm driving every once and awhile, it just randomly squirts down or more like a steady stream comes out then it stops and happens again later.
anyone have this happen to them? If so what did you do?
-thanx
-thanx
I haven't had that problem with my new Z but it did occasionally occur with my 300ZX if the reservoir was too full. Try using the washer for a while to reduce the amount of fluid. Do not continuously run the motor, but do it in squirts.
-thanx
