rays lugnut question......
Old Jun 13, 2006 | 10:47 AM
LvntheZ's Avatar
LvntheZ
Default rays lugnut question......
ok i have a question....... about lugnuts in particular..... i have the rays dura nuts....and was wondering if anyone has had a problem with these.....it seems as they make a wierd noise.....they are torqued to 84 lbs...... just wondering if anyone has ever had problems with them?
Old Jun 13, 2006 | 02:08 PM
DavesZ#3's Avatar
DavesZ#3
When did they make a weird noise? While you were tightening them? Do you use any anti-seize compound on the threads to keep the aluminium lug nuts from binding on the steel studs?
Old Jun 14, 2006 | 11:38 AM
Redfoot's Avatar
Redfoot
Yes they make a good creeking noise when losening them up. I use them when I am at the track & torque them to 95 ftlbs. It's like they get semi stuck to my Volks. Seems to go away after a few more trips on & off the studs.
Old Jun 14, 2006 | 12:42 PM
LvntheZ's Avatar
LvntheZ
yeah exact same noise.....and i lubed the lugnuts.....it actually went away now.....and everything sounds normal......thanks guys....
Old Jun 14, 2006 | 12:44 PM
LvntheZ's Avatar
LvntheZ
whats a good anti-seize compound? cuz it seems they do get stuck to the studs.....
Old Jun 14, 2006 | 02:06 PM
DavesZ#3's Avatar
DavesZ#3
I found a Locktite Anti-seize stick at AutoZone. It looks like a glue stick.
Old Jun 15, 2006 | 12:49 PM
LvntheZ's Avatar
LvntheZ
cool thanks
ablaine
Nov 29, 2016 10:13 AM
