strut bar adjustment
Old Oct 13, 2006 | 11:01 PM
dragonbz99's Avatar
dragonbz99
Default strut bar adjustment
i was trying to shorten my strut bar today, after installing plenum spacer. i didnt loosen the jam nuts when i took the strut bar off, now its stuck. Does anyone know of a way to loosen these?
Thanks
Old Oct 13, 2006 | 11:08 PM
What is stuck? The locking nut?
Old Oct 13, 2006 | 11:10 PM
dragonbz99's Avatar
dragonbz99
yea, the jam bolt on the inside.
doh, its not taking spaces but the one on the inside
Old Oct 13, 2006 | 11:18 PM
The locking nut is the one in the center.
Try a couple of drops of penetrating fluid.
Is it misthreaded?
Are you turning it in the correct direction?
Old Oct 13, 2006 | 11:26 PM
dragonbz99's Avatar
dragonbz99
the third nut from the left. the jam nut. it can't be threaded cuz it never budged. maybe i need a longer monkey wrench? ill try to spray it with some oil tomorrow. i was pulling towards the front of the car. is that not right?
Old Oct 13, 2006 | 11:36 PM
It has been awhile since I installed the spacer. I cannot remember which direction I turned the nut.
Old Oct 13, 2006 | 11:38 PM
dragonbz99's Avatar
dragonbz99
haha its ok. thanks alot though
Old Oct 22, 2006 | 12:58 PM
DanielW's Avatar
DanielW
not to hijack this guys thread but i just installed my 5/16 spacer and it may be alla in my head but I feeel a slight vibration in the steering wheel when i get it above like 75. Was this there before and I'm just noticing it now because I'm paranoid? Or do i need to adjust the strut bar?
Old Oct 22, 2006 | 02:32 PM
Mazinger Z's Avatar
Mazinger Z
I just used a regular crescent wrench. Remember to turn it to the LEFT. It's probably pretty tight, but use some force, it should come loose.
Old Oct 22, 2006 | 02:34 PM
halfass872's Avatar
halfass872
if you are turning towards the front of the car, then you would be tightening it against the strut bar, you want to turn it towards the windshield.
Old Oct 22, 2006 | 05:20 PM
Eazzy's Avatar
Eazzy
I forget but that side may be Left handed thread ---look close to ur threads---U may be tightening , not loosening
Old Oct 22, 2006 | 06:25 PM
plumpzz's Avatar
plumpzz
righty tighty, lefty loosey. those 4 words can help you a lot!
Old Oct 22, 2006 | 06:29 PM
Eazzy's Avatar
Eazzy
UNLESS its a left hand thread ---then --righty loosey , lefty tighty
Old Oct 22, 2006 | 06:35 PM
Eazzy's Avatar
Eazzy
Just walked out to the car ---Right hand nut is LEFT HAND THREAD---Left Nut is RIGHT HAND THREAD------U TURN both, left, and right nut ---top towards the front of the car.
In fact if u look at Davidv's pic ---u will see that the right threads are left hand and the left threads are right hand ---On his pic ---turn BOTH towards the lower right hand corner of the pic
Old Oct 26, 2006 | 11:01 PM
dragonbz99's Avatar
dragonbz99
Thanks! i might have been turning the wrong way. but just put soem pressure on it and it came loose. now i got the spacers in and strut bar on too. hood and plenum clearance are good! motordyne is awesome.
Old Oct 27, 2006 | 01:23 AM
Eazzy's Avatar
Eazzy
Excellent
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
