Window Problems
Old Oct 16, 2006 | 11:40 AM
50 Freak's Avatar
50 Freak
Default Window Problems
Anyone have the same problem as I am noticing on my 06?
After I turn off the engine, I flick the switch on the window and it rolls all the way up then instead of stopping, it rolls down half way. Then I will try to roll it up again and it keeps rolling halfway down.
Basically I have to turn on the engine and then it will roll all the way up.
Old Oct 16, 2006 | 12:19 PM
OCZTrack's Avatar
OCZTrack
I've experienced the same thing but mine happens at completely random times. Seems like it happens more when I'm going at slow speeds (20-30 MPH). It only happens on the passenger side and if I hold the window button in the up position for a second after it is all the way up it will stay up and not go back down.
shushikiary's Avatar
shushikiary
voltage out of the batter is about 12v, voltage out of the alternator is about 14v... the motor has more power when you put 14v across it than 12v, just like running a 12v fan off 14v, it blows more air as it spins faster... I'm going to bet that's the reason for what it's doing, add in the fact that maybe the motor is dying and weaker than it should be, or you have more drag on the window than normal....
note: my does the same thing, but randomly as above person said... but on the driver side
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
