Anyone seen this???
Old Oct 29, 2006 | 10:14 PM
pimpsta's Avatar
pimpsta
Default Anyone seen this???
It happened two nights in a row. "Break", "VDC", "SLIP" all lighted up after i started up the car, and continued to stay on until I turn off the ignition. And they light up again after restart. Everything is working fine, and yes, E-break was released all the way and I did not disengage VDC after ignition. The only thing that i can think of is the cold weather. Everything seems normal during the day (nothing came on). In both instances, all three lighted up ONLY at night, around 60 degree according to the thermometer. Any ideas?
Sorry about the quality of the pics, took it while driving with my phone. And I didn't buckle up, hence the "seat-belt" light. Thanks everyone!
Attached Thumbnails Anyone seen this???-1029_225003.jpg   Anyone seen this???-1029_225046.jpg
Old Oct 29, 2006 | 10:41 PM
1redZ983's Avatar
1redZ983
wow. thats strange. never seen that before. it could be the cold weather. do you park your car outside? if you still got your warranty head over to your nissan dealership.
Old Oct 29, 2006 | 11:03 PM
XuperXero's Avatar
XuperXero
That happened to me before. Because I pulled the VDC fuse out for track. It goes away after I put it back on and restart the car.
Maybe your connection with the VDC fuse isn't working well or VDC fuse is gone, check the fuse box under the battery cover.
Old Oct 30, 2006 | 10:02 AM
NoahzBurnt's Avatar
NoahzBurnt
brake pads are low...happened to me.....when the pads are worn down they require more fluid to get them to grip....this causes the fluid levels to dip causing the car to fail it's ABS and VDC tests...which disables the systems and causes the lights to come on.
Old Oct 30, 2006 | 12:43 PM
MikeW's Avatar
MikeW
Same thing happened to me the other day. Running with VDC off, weather was warm. As I approached a red light the ebrake light flashed and then the tach started spiking. Car ran fine. After a while everything was normal. Since then, no problems.
Old Nov 1, 2006 | 09:31 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
It happend to me before... once after turning off the car after being on the dyno... and another time after being on the track alot...
I forgot what exactly it meant when we pulled the code...
We can check and see if you want to bring it in... what ever it was, it is stored in your Z...
Old Nov 2, 2006 | 04:58 PM
350V's Avatar
350V
Unhappy Airbag light
Anybody else's airbag light stay on and flash while you drive??? I've got an '04.5 touring.
Old Nov 2, 2006 | 05:17 PM
zeeanswer's Avatar
zeeanswer
Never would have thought that was the cause. Nice.
Old Nov 3, 2006 | 09:33 AM
Catch22's Avatar
Catch22
good timing, ive got the exact same problem as of a few days ago and my breaks have been makin some noises... are we sure this is the cause?
Old Nov 9, 2006 | 05:59 PM
pimpsta's Avatar
pimpsta
For the few of you who follow this thread, Jason at Performance Nissan took real good care of me. They found out that not only I'm low on brake fluid, all 4 disks were wearing thin and all the pads need to be replaced. Jason recommended StopTech's stage two (pads, rotors, steel brake lines, and fluid) and I went with it. Although labor was costly ($500 somethin'), it was well worth it. So Noah was right!
Old Nov 10, 2006 | 04:22 PM
MikeW's Avatar
MikeW
Thanks for the update.
Old Nov 16, 2006 | 06:22 PM
6spdRedline's Avatar
6spdRedline
Thanks Guys...I had this today and was freaked out! So brake fluid and new Pads are the trick eh?
Old Nov 17, 2006 | 12:27 AM
pimpsta's Avatar
pimpsta
Can't promise you that's the solution, but I'll say top off fluid and see if it goes away. And have your brakes checked. It's better to find out sooner than later when you find out you have no brakes by crashing into something.
