Fuse? Wiring? Relay? Deadwire?
Old Nov 12, 2006 | 06:04 PM
mr. sparco's Avatar
mr. sparco
Default Fuse? Wiring? Relay? Deadwire?
I was wiring up 06 headlights to 05 non hids and got everything down correctly on th left side. However, I wasn't careful on the right and accidentally plugged a wire up to the wrong pin and boom a fuse blew. One of the 15 amps inside the engine bay. Replaced fuse, checked all other fuses 3x's and yet headlight still wont work, checked all fuses under the dash as well.
Right side works perfectly, left side parking and turn sigs work only. I double checked my L HL on the other side to make sure it wasn't the bulb or ballast, still works on other side with the L HL plugged into the R side harness. What else could it be if its not a fuse? If I blew a relay which one would it be?! NEED HELP! Much appreciated it!
Old Nov 12, 2006 | 08:12 PM
mr. sparco's Avatar
mr. sparco
MODS: Delete this post because I figured it out! WOOHOO!
350Z_Al
Oct 29, 2020 07:44 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
Beater350z
Sep 9, 2015 03:36 PM
