Still having idle problems
Old Nov 28, 2006 | 06:35 AM
slowerz's Avatar
slowerz
Default Still having idle problems
I have an 03 and the idle sits at about 1100rpm. I did the idle volume relearn. It drops the idle to 700, when I turn the car off and then back on it goes right back to about 1100rpms. The only code I get is p0507. I took it to the dealer and I guess they did the same thing. They said they could not figure it out. Has anyone heard of this. Any suggestions? I have already tried checking for leaks and checked the pcv. The idle is not erratic, and does not change in different conditions. I changed all intake piping as well.
Old Nov 28, 2006 | 06:53 AM
Old School's Avatar
Old School
Shift_Boost
sounds like a bad ecu. find another board member in your area with a Z and see if you can swap it. That would help determine if that is infact the culprit. Either that or the TPS signal is incorrect. Maybe someone else can chime in.
Old Nov 28, 2006 | 08:19 AM
slowerz's Avatar
slowerz
Yeah I think it might be a tps problem. I reset the light and it will stay off, when I get on heavy throttle then let off it comes on. But when I drive conservative the light stays off. Also when I shut the car off the throttle valve makes a wierd sound, like its stuck or scraping. It is not the regular sound of the valve closing. It could be the tps because I had nitrous installed connecting to the tps. I am going to try to switch out the throttle vavle with I friends and see what happens.
Old Nov 28, 2006 | 06:39 PM
alrific's Avatar
alrific
When you did idle air learn did your scanner tell you it had been completed.
What did you use to perform idle air? Did you use Consult or an aftermarket
scanner? If idle air was not done right the car will do exactly what your explaining. Doubtful its an ecm. W/the drive by wire system having everything sealed into the single unit of the throttle body wiring nitrous into the tps could block the ecm's ability to relearn the idle. And yea your right the nitrous is making the throttle make that sound.
Old Dec 28, 2006 | 10:08 AM
thommy's Avatar
thommy
Look at this:
http://www.nissanhelp.com/Ownership/...NTB05-067-.htm
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
