need help on p1122 & p2135 codes
I had all mods in sig running great. Well, I decided to replace my skunk spacer for a Crawford plenum because the hood rubbing and looks finally got to me. Anyway, removing the old spacer creased the gasket but I decided to install the Crawford. It was leaking causing rough idle but rev'd up fine so I shut it down and got a new TB gasket and plenum gasket. The TB gasket was because I had to swap the TB to the new plenum. So, I re-installed everything with the new gaskets and I oiled them and torqued everything down to spec.
*critical info*
My battery was dead during the first install because I was adding gauges which are not hooked up to any wiring right now or ever. So when I had my wife steer while I pushed it back in the garage we left the ignition on. Also, I've put 6,000miles on this thing in almost a year and a half, so lets just say it was sitting for about a week even before we finally killed the battery.
OK, so now every things checked, torqued and charged(enough to start the car)
Won't even idle but for a few seconds before dying, so I do throttle re-learn and it will idle but its in limp mode.
I put a scanner on it a few minutes ago and I got codes p1122 Manufacturer Cont. Fuel/Air metering & p2135 TPS/Pedal Position Sensor/ Switch A/B voltage correlation. Funny thing is, before, when it was just rough idle but it would rev, I didn't notice my ses light. But it came on after the second install.
The scanner read the codes but would not erase them and the battery is dead again.
I think what happened was the original leak caused the 1122 code and the battery just having enough juice to start but not maintaining voltage caused the p2135 code. So my game plan is to let the battery charge for a few hours and se if i can clear these things because I think at least the leak is fix but i might have to get a new battery from all the abuse I'm putting it through.
Sorry for rambling incoherently, but I've installed all my mods myself without any problems until now. I think I'm on the right track I was just looking for comments or concerns.
Thanks-
Jay
*critical info*
Thanks-
Jay
OK, the scanner will erase p1122 but wont erase the p2135. I installed a new battery but even erasing the p1122 code doesn't last for it comes back on when I try to start the car. It still won't idle for long. I'm thinking that maybe the dealer has to reset this for me?
I guess I'm talking to myself but, If someone gets both these codes at the same time its most likely that the plug for the TPS is not connected properly or at all
Now, if I can only get this damn plenum from leaking!
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
