Window Problem?
Old Apr 27, 2007 | 06:09 AM
skwid's Avatar
skwid
Default Window Problem?
Hey guys,
My Passenger side window this past week has started doing something weird.
You know how when you open the door the Z indexes the window down a little and when you close it, it goes back up.
Well mine has quit doing that. The window rolls up and down perfectly and the auto up/down works fine but when I open the door it doesn't bump down like it used to. It's a pain in the ***.
Any help would be appreciated.
Old Apr 27, 2007 | 07:20 AM
HondaKiller's Avatar
HondaKiller
there is a rubber **** on the door sill that activates this. Make sure it isn't jammed in or malfunctioning. You should be able to push the button in and release it and the window will go up when you push it in and go down when you release it.
Old Apr 27, 2007 | 09:09 AM
skwid's Avatar
skwid
I figured it had to be that.... My nitrous line runs right through there so it might have flexed up and damaged it or something. I'll check it this weekend when I pull the plastic all out.
It started after I did some hard pulls at the track
Thanks!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
