window rattle when its all the way up?
Old May 7, 2007 | 09:55 PM
xlucidx's Avatar
xlucidx
Default window rattle when its all the way up?
alright so with my window up and i hit a bump going down the 4 lane my window rattles fairly loudly
like its not far enough up into the rubber to keep from rattling
it also seems like the window wobbles when i shut it
i think the guy before me would open then door an not give the window enough time to "drop" before he opend the door and thats why the window rattles now
the passenger side barely drops down and dosent rattle at all
would a window reset fix this??
thanks guys
Old May 7, 2007 | 11:38 PM
gthompson097's Avatar
gthompson097
Take off the door panel and make sure everything it tight inside, you probably had a bolt or two that loosened up.
Old Mar 14, 2012 | 03:03 PM
MikeBit's Avatar
MikeBit
Old thread, but I have this issue. My driver side door rattles from time to time when it is rolled all the way up. I press against it and the rattling noise stops. Also, it barely props down when I open the door. Doesn't give me that half inch clearance it used to. This started happening after I opened the door up to install spacers on my speakers. Think a bolt isn't tight enough somewhere?
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
