anyone had this problem before???
Old May 22, 2007 | 03:39 PM
tyler_seiner's Avatar
tyler_seiner
Default anyone had this problem before???
k just started leaking transmission fluid... jacked up the front end and investigated, found the leak wasn't near the transmission at all. there was a hose from the bottom of the radiator to some thing else and it had a worn hole in it... spilling red liquid.... then i noticed that the radiator was loose... the entire THING MOVABLE!!!!
i noticed that its held up by two bushings thats it... i was missing the bushing on the right so the radiator/fans fell into the hose... the thing that saved my life and my engine... that little hose made enough clearance to where the fans/radiator were 1/2 inch away from my engine....
for the time being I clipped off the hose where the leak was and reattached it luckily there was enough slack so i could salvage the hose... and for the bushing.... i know its trashy but i used a shop rag and balled it up and shoved it in there..... any way i haven't got the bushing yet and i was wondering if anyone else had the same problem, and if so how much was the bushing???
Old May 22, 2007 | 03:50 PM
trains1937's Avatar
trains1937
Get in for service ASAP. Are you still under warranty?
Old May 22, 2007 | 04:16 PM
tyler_seiner
no its an 04 i bought it as is without warranty
Old May 22, 2007 | 04:38 PM
THE TECH's Avatar
THE TECH
Just call the local dealer. Should be a simple fix.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
