fluids...
im puttin the z on the lift this week to change its oil, tranny and diff fluid, and flush the radiator. its got 42,000 miles on it...anything else i should look at or replace??? ive had the car since 20,000 miles and nothing but engine oil and air filter have been replaced. any input would be greatly appreciated.
ROYAL PURPLE, you can't go wrong with any of their products, oil, 75 weight trans oil this stuff meets Nissan's specs, and in the radiator try some purple ice it will make your cars temp drop approx 15 degrees on average. You get what you pay for, doesn't your Z deserve the best?? You should look at replacing the all of the belts, & hoses for piece of mind, maybe the wiper blades and just take a good look at the underbody and insure nothing is loose or in serious need of repair. I usually pre plan my maintenance, but always find something that needs attentions when I finally have the time to work on my Z..... REMEMBER YOU BOUGHT THE Z DO THE WORK YOURSELF
5 quarts RP 5W30
7 quarts 75w90 gearmax
Purple Ice (how much do i need?)
is that what you'd recommend? also...exactly what hoses and belts? and where to get those?
thanks for the help
Your accessory belts. You can purchse them right from Nissan, or go to one of the sites on this fourm. Courtesy (sp?) Nissan sells them as well I believe. Its not too hard to change and only takes like 1/2 really. I just changed mine 2-3 months ago.
Originally Posted by rs90808
like power steering and AC belts?
http://www.courtesyparts.com/betasit..._880_4408.html
I heard the purple stuff isnt good for the Z.
how much purple ice?
