lol I was under the impression that it will be behind the interior fuse box.. and now that I read the whole thread again I realized you been saying it's behind the battery the whole time 😬😬😬
Hah.. No prob. BUT, you're looking for your HVAC Blower Motor fuse, right? And that is behind that kick panel.
not the fuse it's a relay.. My blower fan works at random and after researching people area saying thats usually what's wrong.. so I bought the relay and couldn't find the location for it
The relay is located on the back side of that fuse panel. There should be a diagram specifying the fuse/relay location on the opposite side of the cover.
wait wait wait so you are saying the relay would be behind the interior fuse box near the dead pedal?
How can I get behind that fuse box??
I spent over an hour looking for all the screws that hold that box but I am completely clueless 😣
I didn't even think there was a blower motor relay behind that panel, but that's what the G35 forum says. Apparently there's two blue relays back there and one of them is for the blower motor. I don't know about this though. I'll have to check my own car to verify, and if so, then I also learned something today..
The RELAY is behind that fuse box near the dead pedal not under the hood.. I just replaced it and the blower fan engages every time.
I had the same issue. Check the three-wire clips(right front of fuse box 2 white and 1 colored) that connects ecu. In my case, last clip was broken. This one connects the refrigerant pressure sensor. I hope this helps someone
