Won't go into gear
Old Apr 28, 2015 | 09:51 AM
chigg's Avatar
chigg
Originally Posted by 92K1500
Drill it and use an easy out. It shouldn't be in there that tight.
I replaced my pivot ball with a chromoly ball when I installed my JWT clutch. about 20k miles later and still working fine.
I just removed my bell housing off my 03 g35 and the problem was the pivot ball is broken. half of the bolt is inside of the bolt threading. now i'm stuck between buying the part where the pivot ball attaches or drill the rest of the bolt out.
Old Apr 28, 2015 | 10:10 AM
92K1500's Avatar
92K1500
I would try to drill and easy out it first. Don't go too deep though. Get the new pivot ball first so you can see how long the threaded part is so you can see about how deep you could drill without getting into the transmission.
Old Oct 7, 2019 | 12:51 PM
1slowvq's Avatar
1slowvq
Default G35
Originally Posted by carrera4s
I have a new JWT clutch in and I checked the fluids. The clutch seems to work fine but the shifter won't go into gear. When the car is off the shifter works fine though. When its on it won't go into gear.....so confused
Hey whatssup wondering if you ever found your issue I’m having the same problem with mine and I can figure it out let me know please thanks
Old Oct 7, 2019 | 01:05 PM
travlee's Avatar
travlee
Master
Op.hasnt logged in for almost 10 years, helluva dead thread bump
Old Oct 8, 2019 | 06:30 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Was the clutch just installed? Did you put the disk in backwards?
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Tochigi_236
Sep 27, 2015 03:40 PM
