Reset/Adjust window pinch control
Old Apr 29, 2008 | 08:51 PM
toothlessracer's Avatar
toothlessracer
Default Reset/Adjust window pinch control
My passenger window rolls down about 6 inches when I use the auto up. I had this happen back in '03 and dealer fixed it since it was under warranty. It's doing it again but it's out of warranty.
Does anyone have a step by step on how to adjust the motor so it doesnt do this?
Old Apr 30, 2008 | 04:01 AM
SSZVirginia's Avatar
SSZVirginia
Per Hazade in another thread.
Assuming this is the problem, here’s how to reset the sensor..
After taking off the door panel, find the reset switch.. it’s a black rubber button located inside one of the holes in the metal.
While holding the door close switch, press and hold the reset switch while rolling the window all the way down (do not use the auto-down method).
Release the reset switch, but keep the door close switch held in and roll the window all the way up (do not use the auto-up method).
Release the door close switch and check to make sure the window is adjusted correctly.
Old Apr 30, 2008 | 04:20 AM
CSF's Avatar
CSF
from a g35 service manual...but should be the same or similar:
http://g35driver.com/forums/attachme...0&d=1206367810
Old Apr 30, 2008 | 06:31 PM
jpanic's Avatar
jpanic
I have this problem and it's the most annoying thing in the world. Mine does it all the time even when I don't use the auto roll up feature.
I will try reseting.
Old May 4, 2008 | 09:13 AM
toothlessracer
CSF,
thanks for the info. I will try to reset and hope it works.
Old May 5, 2008 | 09:04 AM
ladyzed's Avatar
ladyzed
VERY annoying. My passenger window is to the point where auto down works, auto up does NOT, and when the door opens, it rolls down but will not go up after shutting door.
Old May 5, 2008 | 11:40 AM
j.arnaldo's Avatar
j.arnaldo
It's a "regular" issue in our monZters; also, the hatch door struts not holding it open, especially in cold weather. Finally, the gas latch release thingie not opening the door [that gives you access to the tank]. THE GOOD NEWS IS, none of those annoyances will leave us marooned at 3:OO AM on the free-
way!!! We can actually deal with those issues as time & pocket allow. NO PROBLEMO!
____________________________________________________________ _____
'O4 Touring Coupe/13k!!!/$20,500k!!! NO FEATHERING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
