Help~
Old May 14, 2008 | 05:40 AM
playaaa's Avatar
playaaa
Default Help~
i need help from you guys...i own a 2003 350Z (touring edition). lately, when i drive my car, i see the "brake" sign along with "slip" and "VDC off" signs. is it because my brakes are worn out? someone told me it might be because my tires are worn out. if anyone had the same problem, please help me out. thanks~
Old May 14, 2008 | 05:50 AM
What size tires are you running front and rear?
Old May 14, 2008 | 06:02 AM
playaaa's Avatar
playaaa
i dont know the exact size of the tires, but they're on 18 inch rims.
Old May 14, 2008 | 06:26 AM
bmaiZ's Avatar
bmaiZ
i guess you better go check...hmm
Old May 14, 2008 | 07:30 AM
krnzzang84's Avatar
krnzzang84
you should have 225/45/18 and 245/45/18, if you don't it may cause vdc light even though u are not slipping. check the wheel section and read tire size thread
Old May 14, 2008 | 07:40 AM
playaaa's Avatar
playaaa
yup, those are the tires i have.
Old May 14, 2008 | 08:01 AM
Tire size is fine.
a. Check brake fluid level.
b. Check brake pads.
If neither solves the problem then take it to Nissan for more serious diagnostics.
Old May 14, 2008 | 08:47 AM
HondaKiller's Avatar
HondaKiller
your brake pads are low.
