Brake Fluid
May 22, 2008 | 07:08 PM
Brake Fluid
I searched for a while and found a couple of things but I still want to ask.The owners manual and Service Manual says to use dot 3, is it ok to use dot 4 (like Motul RBF 600?).* Also what fluid would you recommend for the clutch?
May 22, 2008 | 07:10 PM
yes it is ok to use dot 4. I use ATE super blue for the brakes and the Motul RBF600 in the clutch.
May 22, 2008 | 07:11 PM
i use same fluid for clutch and brakes
May 22, 2008 | 07:31 PM
Quote:
How often do you change the clutch fluid?
ps; where are you stationed in SD? Im at North Island. Squadron.
May 22, 2008 | 07:53 PM
May 22, 2008 | 07:57 PM
+1 minus the motul clutch juice. You are supposed to change out the fluids approx every 12-18 months, possibly more often if you are in a high humidity area. Brake fluid is hygroscopic, it absorbs water even the good stuff.
May 22, 2008 | 08:04 PM
The good stuff more so than others, I would say if you run motul, superblue,etc. you have to be on top of the flushing/changing regimen.
May 22, 2008 | 09:21 PM
Yea, I change out my clutch fluid and brake fluid (both motul rbf600) once a year. I might try the Amsoil dot4 next time.
May 22, 2008 | 09:24 PM
Im sold on amsoil everything else? didnt think about brake fluid, i will try that next time round.
May 22, 2008 | 09:33 PM
how many bottle do I need for brakes and clutch?
May 22, 2008 | 09:36 PM
I used 2 1/2 big bottles for my brakes, not sure on clutch. I'd say 4 liters to be safe?
May 22, 2008 | 09:47 PM
what size bottles where u using? was it the same ones they sell on mynismo?
May 22, 2008 | 09:48 PM
Dont know size right off hand, i just went w/castrols dot 4 (bigbottle)
May 23, 2008 | 01:44 PM
Quote:
i'm putting some amsoil in this weekend
May 23, 2008 | 06:01 PM
Castrol SRF went in when I installed new brake lines on my '03 track model. No complaints at all.
Oct 12, 2012 | 02:18 PM
ARMSTRONGARMS
Yea what size are u using when u say "big" bottles?
Oct 12, 2012 | 02:32 PM
JETPILOT
DOT 4..... Confirm!
JET
checking in.
Oct 12, 2012 | 04:27 PM
Super Moderator MY350Z.COM
I can bleed the brakes with a half liter of fluid, clutch I usually use under a pint.
ATE blue for my brakes
Normal off the Walmart shelf Dot 4 in the clutch
Oct 12, 2012 | 04:55 PM
Why is that? ...........Seriously
Oct 12, 2012 | 05:08 PM
Chi-TownWarrior
No need, cluch never heats up the fluid enough. Probably would use something else on an 07/08 with the slave in the bell housing
