new Throttle body throwing codes
Old Jun 26, 2008 | 09:34 AM
derek173's Avatar
derek173
Default new Throttle body throwing codes
codes
p1122 - Electronic Throttle Control Function
p2135 - Tp Sensor circuit performance/range proble, tp1 and 2 signals do not agree
Had my fast intentions exhaust installed last week and everything was fine until my car threw a code and went into 15mph limp mode. This happened to me a year ago and I though its probably the throttle position sensor again as it was the same syptoms as last year when my tps went dead. Went to autozone and checked the code and it was the tps. I picked one up today and installed it and the code came back soon after I restarted the car after a short drive. Can my exhaust be causing the code?
Old Jun 26, 2008 | 03:08 PM
DavesZ#3's Avatar
DavesZ#3
How to replace the TB:
Electric Throttle Control Actuator
 Install gasket with positioning no-protrusion surface upward or downward.
 Tighten mounting bolts in numerical order as shown in the figure.
 Perform the “Throttle Valve Closed Position Learning” when harness
connector of electric throttle control actuator is disconnected.
Refer to EC-42, "Throttle Valve Closed Position Learning" .
 Perform the “Idle Air Volume Learning” and “Throttle Valve
” when electric throttle control actuator
is replaced. Refer to EC-43, "Idle Air Volume Learning" .
Do all of that, did you?
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
