how do i do the throttle body relearn procedure???
Old Apr 18, 2015 | 02:24 PM
travlee's Avatar
travlee
Master
i am mostly busting your *****. thanks on the car compliment.
keep the wheels on the ground sir!
Old Apr 18, 2015 | 02:29 PM
Xonatron's Avatar
Xonatron
Haha I know, this forum tends to test the thickness of one's skin. If you lived close I would be asking you for a ride! Huge fan of the 405HP C5 Z06, and onward.
Old Apr 18, 2015 | 02:33 PM
travlee's Avatar
travlee
Master
405.... how cute... haha. mine is the c6 so it has 505, the c5 stopped in 04. if you ever find your way to texas let me know
Old Apr 18, 2015 | 04:23 PM
Xonatron's Avatar
Xonatron
lol I know all about it. The C6 Z06 is a monster!
Old Jun 24, 2015 | 05:26 PM
I DTW I's Avatar
I DTW I
Originally Posted by DavesZ#3
Accelerator Pedal Released Position Learning
Without CONSULT-II
NOTE:
It is better to count the time accurately with a clock.
It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit has a malfunction.
1. Perform EC-42, "Accelerator Pedal Released Position Learning" .
2. Perform EC-42, "Throttle Valve Closed Position Learning" .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
5. Turn ignition switch OFF and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. In this case, find the cause of the incident by referring to the DIAGNOSTIC PROCEDURE below.
In following these directions, I'm stuck on #8, "hold gas pedal til MIL stops blinking and turns on". But the MIL is already on because the key is in the "ON" position, all the dash lights are on.
I follow the appropriate procedure but my MIL never blinks. What am I doing wrong here?
Old Jun 24, 2015 | 07:36 PM
Xonatron's Avatar
Xonatron
I DTW I, here's a video of me doing it, although I wasn't sure on the counting out of the code. Let me know if this helps:
Old Jun 25, 2015 | 03:11 AM
I DTW I's Avatar
I DTW I
Yay thank you so much for posting. I will give it another go after work today.
Old Jun 25, 2015 | 05:24 AM
I DTW I's Avatar
I DTW I
On the 11th try I got the MIL to blink, followed the final steps and yes perfect idle!!!!
I drove it for the first time in a month, came back and restarted it to make sure it still idled well but it went right back to idle at 1,000 rpm! Argh Why?
So I followed the reset procedure again and successfully reset the idle. This time, I drove around for a good 15 minutes, pausing many times to idle so it'd hopefully remember it.
Get home and restart it and it's right back at 1,000 rpm. Why does the car forget the proper idle every restart?
Old Jun 25, 2015 | 04:35 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Ahh crap, mine did that, i can't remember the fix! sorry.
Old Jun 25, 2015 | 04:36 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Oh wait, yes i can!!!!
It's battery level. They're not kidding when they say turn everything off in the service manual.
Before you start, turn of everything, radio, fans, AC, anything, lights for doors. Try it all again, it'll save.
Old Jul 9, 2015 | 04:18 AM
I DTW I's Avatar
I DTW I
You my friend had the answer!!! Even though the directions say nothing about the blower motor being off, that is what made the difference. I drove it around (for the alt to fully charge the battery) and then went straight to the procedure with the blower motor off and radio off and every other possible power accessory off. Lo and behold it worked!!!!
Mods, can we add turning the blower motor, radio off and doors closed to the original directions that DaveZ#3 posted on the first page please?
Old Jul 9, 2015 | 04:01 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Glad it worked (and that i could even remember it!)
The info is there in the instructions, it's just not as clear, most people will not realise their voltage will sag enough to fail this.
Old Apr 18, 2016 | 12:15 AM
dkearns's Avatar
dkearns
Great write up. My RPM dropped from 1000 to approx 600 - (not sure what each of the lower dashes on the rev counter indicate) after doing the relearn - you just know when something isn't right!
Just one point - I did the relearn procedure following accelerator and timing points however at the end I made the mistake of turning the ignition back to the off position rather than going from the ON position to starting the car - if you go back to the off position and then start the car the relearn will not have worked! Just a point I thought worth adding.
Old Apr 10, 2017 | 03:39 AM
Sbornoe's Avatar
Sbornoe
Default Old post alive again.
Does anybody know if the ecu forget the calibration if you have a Main battery switch? And the car is completly out of electricity for maybe a month or so.
Old May 30, 2017 | 04:31 AM
Jp.manuel88's Avatar
Jp.manuel88
Hi i have a 2003 350z and I have the same problem the car start well but when it running a few miles it show down and it have serious problem to start, and when it running 40 m/h and I push the gas don't accelerate just go up slowly, I the computer said the cam and crank sensor I replaced and still the same problem i change the fuel pump and nothing happens I check MAF sensor it'll me crazy please any ideas I need help thanks
Old May 30, 2017 | 04:32 AM
travlee's Avatar
travlee
Master
did you replace all 3 sensors.... put them in the correct banks? did you use oem sensors or cheap aftermarket ones
Old May 30, 2017 | 06:14 AM
Jp.manuel88
I bought in auto part and put in the correct place and steel the problem, I change the fuel pump and check the maf sensor and work fine I dont have idea what's happen
Old May 30, 2017 | 06:29 AM
  #38
travlee's Avatar
travlee
Master
should have use oem sensors
Old May 31, 2017 | 01:56 AM
  #39
Wastah's Avatar
Wastah
whats the scan tool for idle learn for nissan versa/tiida
Old May 31, 2017 | 02:56 AM
  #40
travlee's Avatar
travlee
Master
how many times are you going to ask the same question in a forum that is not for versa's? do you have a learning disability or something?
quick google search would have led you to a versa based forum, located here... now go away
http://www.nissanversaforums.com/
https://my350z.com/forum/maintenance...5797-idle.html
https://my350z.com/forum/maintenance...6025-idle.html
