Low Clutch Fluid
Old Oct 13, 2008 | 11:02 AM
sakefon's Avatar
sakefon
Default Low Clutch Fluid
Well I've just checked my clutch fluid and its below min. level. I was wondering if there is a special way to refill it. Thanks in Advance.
Old Oct 13, 2008 | 11:05 AM
Mike Wazowski's Avatar
Mike Wazowski
you pour it in....with or without a funnel
Old Oct 13, 2008 | 12:42 PM
sakefon's Avatar
sakefon
ok thanks. I was reading some forums and they said something about pumping the clutch while pooring it so I had to ask my350z forum to make sure.
Old Oct 13, 2008 | 12:45 PM
Mike Wazowski
if it is only low you are fine with just adding a little. If you have air bubbles you will need to pump it and use a vacuum evacuator
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
