HVAC Problem
Old Dec 20, 2008 | 12:12 PM
Bov82's Avatar
Bov82
Question HVAC Problem
When my Z is at a stop, the heater blows cold air. However, when I'm moving, the heat works absolutely fine. I have the same issue no matter if the I have the heat set to automatic or manual settings. Has anybody experienced similar issues or could someone possible shine some light on what my problem might be?
2004.5 350Z Touring
Old Dec 20, 2008 | 01:46 PM
jeffie7's Avatar
jeffie7
2004.5 350Z Touring
Pulling this from my *** and making a total guess.
When sitting at a stop with the car at an idle, it might not be pulling enough fluid through the heater core, when you start moving and the RPMs go up, it might be drawing more fluid through the heater system.
Maybe air in the lines? have you had any of your radiator hoses off before? maybe low on fluid? does your car ever seem to run hot?
Again, just pulling this from my ***.
Old Dec 21, 2008 | 02:05 AM
lama's Avatar
lama
Had this problem last year when I bought my car. Turns out there was air in the line. The bleed screw for it is on the passenger side behind the engine. Sorta near the battery cover.
Old Dec 22, 2008 | 07:35 AM
Tim@WestCovinaNissan's Avatar
Most likely air in the system. Could be from not bleeding it good enough if you just did some work on it or could be a bad radiator cap that is not holding correct pressure.
Old Dec 22, 2008 | 11:04 AM
Bov82's Avatar
Bov82
Thanks for everyone's input! I'm going to bleed the system and replace the radiator cap this week. Hopefully that does the trick!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
