So replaced the Wheels Studs...
Old Feb 14, 2009 | 03:21 PM
J350z101's Avatar
J350z101
Default So replaced the Wheels Studs...
So some douche stripped my wheels studs.. by putting the wrong lug nuts on there and cross threading the studs.. So looked on here for a DIY and thought I could get it fine... When I got to trying to take the bolts off/removing the brace from the caliper (22mm 6point) it would not go. broke a torque wrench in the process, then finally torched it and that did it. Guess it had lock tight on it and it took me forever to get it off, considering I didnt have the correct socket at first... Didn't see anywhere on here where it said the brace was such a bit** to get off... pita -_-
**vent :}
Old Feb 14, 2009 | 03:23 PM
Mike Wazowski's Avatar
Mike Wazowski
should have started with the right tools for the job, not trying to loosen a bolt with the torque wrench.
well, live and learn... next time try a breaker bar or even a pipe on the end of a wrench
Old Feb 14, 2009 | 03:31 PM
J350z101's Avatar
J350z101
the auto discount didnt even have a break bar.. that was the first thing i went to buy along with the 22mm socket.. and they said they were discontinued.. they didnt even have a pipe.. they said i could get this shitty exhaust they sell and use the pipe out of that.. i was like.. UMMM no thnx =\
Old Feb 14, 2009 | 03:40 PM
Mike Wazowski
lol
Old Feb 18, 2009 | 01:15 PM
thekinn's Avatar
thekinn
I may need to replace studs at some point.. thanks for the post.
..and for future reference - You can get some good plumber pipe from a Home Depot or Lowes to use as a cheapo breaker bar. Worked for me getting my brake calipers off.
Old Feb 18, 2009 | 01:35 PM
VO...'s Avatar
VO...
Administrator
LOL.
Like USN HM said, invest in a good tool set. Sears sells really good 1/2-drive breaker bars. I have 2, one mid-sized, and one super long breaker bar. Caliper bolts are a sintch with a 2 1/2 foot breaker bar and a 6-point socket...
ablaine
Nov 29, 2016 10:13 AM
