Rear Axle Clicking Service Bulletin
Old Feb 22, 2009 | 09:29 PM
Subninja's Avatar
Subninja
Default Rear Axle Clicking Service Bulletin
I am sure this is a repost but I couldn't seem to find it. This is for everyone who will have to deal with this problem which should be a recall in my opinion.
http://www.notre350z.com/forum/files...ClickClack.pdf
Old Feb 22, 2009 | 09:36 PM
Subninja's Avatar
Subninja
Also where can I get molykote m77 grease?
Old Feb 23, 2009 | 03:09 AM
albinobob's Avatar
albinobob
Did this about a month ago. All the hardware from the dealer for 1 side cost about 20 bucks FYI. And there is no reason to remove the driveshaft completely (if you can get it around the brake line I couldn't) just pull it to the point were you can lube everything that needs it and slide it back in (you do have to remove the geared part from the hub completely I am just talking about taking it out from underneath the car like in the picture). Also go ahead and do both sides. I only bought enough hardware for 1 when I took it off there was barely even any grease residue on it and a month later the other one is acting up. That’s on a '04.
Old Feb 23, 2009 | 04:39 AM
I assume that the grease comes in the kit.
Old Feb 23, 2009 | 01:02 PM
Subninja's Avatar
Subninja
What kit are you talking about and where can I get it? I think you have to order everything seperately!
