Horrible Idle Problem
Old Mar 23, 2009 | 09:07 PM
R3VAN's Avatar
R3VAN
Default Horrible Idle Problem
When the Z is idling for a longish period of time (45 seconds to a minute) its starts acting like it wants to die. It dips down to 500 rpms - 250 rpms and shakes a lot then goes back up then starts going back down until I start to drive again. It also does this without fail when I have my heater or AC on and I come to a stop (I have to turn off my heater/AC when I stop now) or else it will immediately start acting like it wants to turn off.
It has already cut off on me twice.....anyone know wtf is up? Could it be a dirty air filter? My air filter is pretty damn dirty but Im just waiting until this weekend because I get my new intake set up (in the mail).
Old Mar 23, 2009 | 09:10 PM
Spork's Avatar
Spork
Happened to me when I took the Z out for the first time this spring.
At a stop light I looked down and my RPMs were dipping low.
I'm gonna try cleaning the MAF and related stuff and see if it helps.
Old Mar 24, 2009 | 06:26 AM
Frank@MtroNiss's Avatar
Frank@MtroNiss
Default Poor idle
Sounds like you have an idle re-learn problem,,(have you recently had to change or disconnect the battery?)if so you may need to visit the dealer so they can reset your base idle.....if you were closer i would hook you up but kind of a long drive for you im sure....good luck..
Old Mar 24, 2009 | 06:50 PM
crazysojujon's Avatar
crazysojujon
'') do you know what kind of tool they use to reset the idle??
My Z is in Korea and Samsung sells rebadged Nissans... mayeb i can get it reset there.
My car does that too and after i took it to korea with different fuel and all and i have to hold on the gas to keep it idling stable.
Old Mar 25, 2009 | 06:27 AM
Frank@MtroNiss
Default Scan tool
its called consult 2..its a scanner and lets you reset ecu parameters
Old Mar 25, 2009 | 12:05 PM
PerfZ's Avatar
PerfZ
Try this first: http://www.technosquareinc.com/350reset.htm
Old Mar 18, 2010 | 12:20 PM
zwarbyt's Avatar
zwarbyt
worked perfect for me after a battery change, car wouldnt even idle now runs like a top
Old Mar 29, 2010 | 10:08 PM
solar_n_orange's Avatar
solar_n_orange
I'm having a similar issue but my car was throwing a P0300 code after a spark plug change and injen filter replacement. I cleared the code and did the relearn and the problem isn't as bad but the car still has an irregular idle. If you find a solid solution please let me know.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
