vsld fluid
Old Mar 29, 2009 | 07:59 PM
steroid's Avatar
steroid
Default vsld fluid
what fluid should i use??
should i run a thicker gear oil or not?
i tried searching on here but nothing came up because i just bought a vsld off a 04 touring model and im about to install it in my base Z and i would like to change fluid before i install.. so thanks in advance
Old Mar 29, 2009 | 09:24 PM
Tekwon-V's Avatar
Tekwon-V
any GL-5 OEM or equivalent would work. 75W-85 or 75W-90 would work.
Old Mar 29, 2009 | 09:29 PM
steroid's Avatar
steroid
thanks!!!
Old Mar 29, 2009 | 09:47 PM
davidmcc's Avatar
davidmcc
Are you asking about the viscous fluid in the LSD? If that's the case I'd do a little more searching first. I'm pretty certain that VLSD's contain a special silicone fluid and not just GL-5 gear oil. I'm not sure these units are end-user serviceable.
Old Mar 29, 2009 | 10:01 PM
Tekwon-V's Avatar
Tekwon-V
according to the service manual, it's a GL-5 rated gear oil (with mentioned viscosity). it's nothing special.
Old Mar 29, 2009 | 10:13 PM
davidmcc's Avatar
davidmcc
My bad, I was under the impression there was a different fluid housed inside the LSD
Old Mar 30, 2009 | 07:46 PM
steroid's Avatar
steroid
thanks dude.. i seen other forums and they had use any gl-5 fluid
Old Mar 30, 2009 | 09:20 PM
Tekwon-V's Avatar
Tekwon-V
yea it should be mentioned that the service manual calls out GL-5 for the differential and GL-4 for the transmission.
the additive(s) on the GL-5 is apparently harmful to synchros. or so i've read. lol.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Ace2347
Sep 22, 2015 03:12 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
