Climate control not blowing hot air, just room temp.
Old May 27, 2009 | 06:40 AM
nosurf2day's Avatar
nosurf2day
Default Climate control not blowing hot air, just room temp.
am confused as to why my heater is not putting out hot air.
Symptoms. Well I just replaced my AC compressor because it went out. Unfortuately I have to re replace it because the one I put in was bad as well. Needless to say I am pissed.
I was driving tonight and my windows started to fog up, so I turned on the heater to dry them up. The air came on and was blowing well, but there was no heat coming out. Just regular air temp, not heated temp.
I did have to replace the fuse to the airconditioner because it was blown. I didnt know if I may have blown a fuse to the heater so I checked all my fuses under the hood and nothing is blown.
What am I missing, I am sure this has to be inter related.
someone said something about the heater control valve, i dont know where that is to check.
Old May 28, 2009 | 10:12 AM
350 Rookie's Avatar
350 Rookie
You have air in the cooling system. Jack up the front of your car, open the radiator cap, blast the heat and rev the car at 2000rpm contantly, have another person keep topping off the radiator. Make sure you do it somewhere you dont care about, itll get messy
Old Jun 1, 2009 | 11:29 AM
karolin768's Avatar
karolin768
Cool tips for storage
When the simple wedding dresses is collected from the cleaners, it must be prepared carefully for storage. The strapless wedding dress cannot simply be hung in a closet wrapped in plastic or placed in a box. Even the box it come in will not protect the bridesmaid dresses.
Old Jun 1, 2009 | 02:49 PM
nosurf2day's Avatar
nosurf2day
What? I think you posted on the wrong thread.
Problem solved, thanks for the advice.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
