Can someone help me find the scanned copy of the new alignment specs?
I was reading up on this subject the other day, and came across a post which said that Nissan has sent out updated alignment specs to solve the problem. There was also a scanned copy of the new specs. Unfortunately I hadn't bookmarked it then, and now I can't find it. Can someone please help me find the new specs ?
I've had Nissan replace the feathered front tires at 8000 miles, which got rid of the right pull and roar while braking under 30mph. Now approx 8000 miles later, the problem is back, and the fronts are feathered again.
And I read about the caliper tightening approach and also some kind of compression rod replacement TSB, which has to be done along with the alignment to really take care of the problem.
I was at the dealer yesterday and told him that some folks have replaced the potenzas with other tires and done an alignment and the feathering/right pull has stopped. He said that that was because of the harder rubber used on other tires. The feathering will come back, just later than 8000 miles.
Thanks.
Thanks.
