Problem ??? Intermitent Starting.
Hey everyone, I am having a problem with my 2003 z. The battery is new and has a good charge but sometimes it will not start .not because of the engine but because it acts like the battery is very dead. It won't even powery radar detector I will wait for a few minutes and then it will start right up like nothing is wrong. Do u have any idea what could do that? I am thinking that it has to do with the immobilizer. What do I guys think? Thanks for your help
Title edited to reflect thread content. OP, please title your threads accordingly or they will face deletion in the future. Thank you sir, and have a nice day...
VO
VO
check your battery connections. make sure you don't have a lot of corrosion or oxidation on your terminals. Also make sure the terminals aren't loose. If you have a volt meter check ur voltage of your battery. It should be around 12.6, if it's below 12.45 volts you need to get it charged.
It is a new battery, and I just had it checked at autozone. It is not a loose connection or corrosion. That was the first thing that I checked. thanks for the idea, but it is not that easy.
