What to do?
Old Sep 16, 2009 | 09:13 PM
zzzcoupe's Avatar
zzzcoupe
Default What to do?
My air fuel ratio sensor has lit off my "SES" light since upgrading intake what should i do?
1-Replace the sensor and hope it doesnt go off again?
2-Get a fuel management system in hopes that the sensor will no longer go off once the air fuel ratio is correct?
3-Have the car tuned?
Any help greatly apprecieted!
04 z33 SB 6MT Enthusiast
Old Sep 16, 2009 | 09:59 PM
nismonian's Avatar
nismonian
check all the work and make sure maf and sensor are hooked up correctly.
then get a tune.
Old Sep 17, 2009 | 07:18 PM
zzzcoupe's Avatar
zzzcoupe
Thanks for the help. On that note Does anyone know of a good tuning place near northern california?
Old Sep 17, 2009 | 07:36 PM
TheFarmer's Avatar
TheFarmer
What are your mods besides the intake you upgraded?
Old Sep 17, 2009 | 08:01 PM
vthao's Avatar
vthao
Clean your MAF and clear the code. It should go away.
Old Sep 17, 2009 | 10:17 PM
zzzcoupe's Avatar
zzzcoupe
Only engine mod is the intake. But also have aeriated disc brakes and a Nismo short shifter. Thanks for the advice ill try cleaning/clearing it. You NorCal guys near Santa Cruz/San Jose area?
Old Sep 18, 2009 | 07:59 PM
zzzcoupe's Avatar
zzzcoupe
Cleaned MAF and cleared the MIL light 20 miles later light came back on.
ODBII gave code p1273 Air/Fuel Ratio sensor Bank 1...Should i just replace it?
Old Sep 22, 2009 | 05:13 PM
zzzcoupe's Avatar
zzzcoupe
When cleaning the MAF i noticed the housing had a chip out of it and had been patched up with some cement glue leaving the interior surface with 1/16"high of bumpy hard glue stuck to the inside, the patch job is a total of approximatly 1inch by 2inches and 1/16 inch high. could this be altering the MAF sensor reading and in return setting off my Air/Fuel ratio sensor??
