clutch issue..
Old Sep 19, 2009 | 05:18 PM
christian_wlcp's Avatar
christian_wlcp
Default clutch issue..
so my clutch is engaging and disengaging correctly but for some reason it keeps sticking and isnt stiff anymore..
is there a spring that could have possibly broke or something that would allow this to happen??
help is much appreciated.. thanks guys
Old Sep 19, 2009 | 05:29 PM
booboo1343's Avatar
booboo1343
Slave cylinder recall..Mine was doing the same thing and my clutch felt the same as yours. Tell them to check your clutch while their replacing the slave cylinder. I didnt and I had to take my car for a new clutch 8 months later.
Old Sep 19, 2009 | 05:38 PM
DavesZ#3's Avatar
DavesZ#3
Slave recall was for 2007 only, unless OP has that model year it's not the same problem. That's probably not his problem since he says it engages and disengages properly. Slave cylinder problem left the clutch engaged when the pedal was stuck to the floor.
Old Sep 19, 2009 | 06:09 PM
christian_wlcp
It's an 06 base w a little over 40k.. Doesn't make much sense that the clutch would go out especially cause I hardly ever rag on it and i had plenty of clutch left up until about an hour ago. Still can drive it but after I shift I must pull the clutch up the other half of the way w my foot
Old Sep 19, 2009 | 07:27 PM
cheshirecat79's Avatar
cheshirecat79
Do a search for "clutch pedal stuck" and you'll find more than enough info. Good luck.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
