plenum leak please help.
Old Nov 7, 2009 | 10:57 PM
quietkilla6's Avatar
quietkilla6
Default plenum leak please help.
im getting a hiss noise like a leak from the air intake plenum.
i cant find part # or even the part for that matter.
Seems like it could be the hose on the left above the strut bar definitly left side of the plenum i just hoping its not the plenum gasket.
Anyone know where i can get a diagram of all the hoses that come off the sides of the plenum? Possibly with a purpose description? maby a place to start looking for replacements?
help please
Old Nov 8, 2009 | 04:24 AM
DavesZ#3's Avatar
DavesZ#3
The best place to get info on them is the service manual CLICK HERE
That car doesn't look that old, so I'd be surprised that a hose would need replacement. I take it you've done no mods, so somenthing coming loose should be out of the question too.
Auto part stores used to sell cans of leak detector, you'd spray it around the area where you suspected a leak and the vapor would be sucked into the leak. It would cause your engine to run faster for a second or two so that's how you'd tell where the leak is.
Old Nov 8, 2009 | 05:12 AM
Jay'Z's Avatar
Jay'Z
You need a new gasket, its only 30 bucks or so... Start from there.
Old Nov 8, 2009 | 08:22 AM
quietkilla6
That pic was to give you an idea wich hose I think its comming from lol my cars a bit older and dustier. No mods.
Old Nov 8, 2009 | 08:26 AM
bottlefedZ's Avatar
bottlefedZ
lol...I was about too coment on a very clean and detailed engine bay....I would also think it would the plenum gasket.
Old Nov 8, 2009 | 10:08 AM
MDeezy's Avatar
MDeezy
Listen to the car while running move your ear around and try to pin point a location
inspect gaskets.
fill spray bottle with soapy water... spray area(s) to see if you can find the leak.
or go to parts store for leak detector...
Old Nov 8, 2009 | 11:11 AM
xxbrokkxx's Avatar
xxbrokkxx
Mine makes that sound also. I dont think its the plenum i think its the hose that leads under the battery compartment. My car runs fine with it making that hiss noise though, and the dealership said its normal which i doubt but... let us know what it is when you find it.
Old Nov 8, 2009 | 11:30 AM
DavesZ#3's Avatar
DavesZ#3
inspect gaskets.
I think the soapy water tricks only work on pressurized leaks, not vacuum leaks. Under pressure, bubbles form on the outside. Under vacuum, leaks would form on the inside and you'd never see them.
As for needing a new gasket, unless you've opened up the plenum, then that's highly unlikely.
Look for leaks around the center bolts of the plenum or the hose connections, especially if one is loose. The hoses fit very tightly.
Old Nov 8, 2009 | 12:08 PM
quietkilla6
This is definitly not normal.
inspect gaskets.
thanks im going to try that. Ive only looked at night under dim street lights. Its worth a try to save the money and if that doesnt work ill go for the detector.
yea I bought the car used but i havent changed anything except knn filter.
im almost certain its a hose conection. Really id just want a plenum diagram that shows me all the air hose connections ive searched google and courtesy parts to no avail. its such a simple fix that i dont want to take it to a mech.
Old Nov 8, 2009 | 01:59 PM
DavesZ#3's Avatar
DavesZ#3
I gave you a link above that will allow you to find a factory service manual. That has everything explained.
Old Nov 8, 2009 | 02:51 PM
quietkilla6
i clicked that from my black berry and the site poped up but i didnt google it for me... thanks guys youve been alot of help.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
