Can't get rid of P0037 code
Old Dec 21, 2009 | 01:26 PM
dkmesa350z's Avatar
dkmesa350z
Going underneath my Z after work tomorrow to visually inspect. If nothing, I will try to replace the sensor.
Since your code came back, maybe your sensor was not bad in the first place...I kind of want to buy your original if you are willing to sell it, to avoid paying $150 at the dealership.
Old Dec 28, 2009 | 04:09 PM
tnk210's Avatar
tnk210
Going back in to the dealer tomorrow.
I hacked up my other O2 trying a MIL fix. No luck. Spark-plug non-foulers didn't work either.
Old Dec 31, 2009 | 09:19 AM
tnk210's Avatar
tnk210
Dealer checked in today...it appears to be a bad ECU. When the car is cold, the O2 sensor does not receive the 12V source and throws the code. When warmed up everything appears fine. I think he said he believes its one of the ECU ground pins. Once they get the new ECU we'll know for sure.
Old Jan 8, 2010 | 03:48 PM
tnk210's Avatar
tnk210
New ECU in. Ran fine yesterday but when they started it today it was running rough and threw another code. I believe they said it was a camshaft position sensor so now they ordered that part. Hopefully this solves it?
Old Jan 8, 2010 | 04:23 PM
Snowboarder714's Avatar
Snowboarder714
I took my car into the dealer also...
How much is your dealer charging you for the ECU?
Old Jan 8, 2010 | 04:24 PM
tnk210's Avatar
tnk210
Its being covered, so nothing. Not sure about the new sensor though.
Old Jan 8, 2010 | 04:27 PM
Snowboarder714
Cool you're lucky.
My car is not under warranty.
When you get a chance... can you ask the tech if the ECU part numbers have to match up?
I'm trying to find a used one.
Old Jan 8, 2010 | 04:32 PM
tnk210's Avatar
tnk210
I believe it needs to be the same make and model, but I'll try and ask him on Monday.
Old Jan 8, 2010 | 05:05 PM
Snowboarder714
Thanks a bunch
Old Jan 8, 2010 | 07:15 PM
dkmesa350z's Avatar
dkmesa350z
I replaced my o2 sensor with a factory one for $130 and problem solved!
Sorry yours is being more stubborn.
Old Jan 11, 2010 | 03:41 PM
tnk210's Avatar
tnk210
Edit: Service writer got confused. Car threw the same code with the new ECU NOT a new code. New O2 sensor on order, hopefully that fixes it :-/
Old Jan 11, 2010 | 07:55 PM
Mike@Blackline's Avatar
Mike@Blackline
shouldnt live in CA
Old Jan 12, 2010 | 10:53 AM
tnk210's Avatar
tnk210
If this doesn't fix it I'm going to try and use my Cobb AP race tuner to block that code. Someone on the forums said that should work.
Would it appear ok during a smog check? I'm not sure if flashed ECU's read the same when hooked up.
Old Jan 16, 2010 | 08:50 AM
tnk210's Avatar
tnk210
New o2 didn't do anything. The tech ran separate wires from the ECU directly to the o2 sensor and confirmed its not the specific o2 wires causing the error. Everything appears fine, but a calculation error keeps occurring. They have a call into tech support and are going to bring in another '03 to check grounding points. What a f*cking nightmare.
Old Jan 16, 2010 | 09:42 AM
str8dum1's Avatar
str8dum1
that will absolutely not pass inspection.
good luck with the issue. seems like you have covered all the easy fixes.
Old Jan 18, 2010 | 11:15 PM
Snowboarder714
Wow sorry to hear your problem is not fixed after a new ECU and o2 sensor
Keep us up to date.
Old Jan 20, 2010 | 03:17 PM
Zomgfast123's Avatar
Zomgfast123
wow man, sorry to hear . im having a similar problem, p2a03 code, a/f ratio sensor - sensor 1 b2. nissan is blaming it on my welded in o2 sensor on the same side cat. i think its BS, so they wont replace the sensor until i have new cat. but now im looking into a new cat for 07-08.
Old Jan 20, 2010 | 04:18 PM
  #38
tnk210's Avatar
tnk210
Got a message from the tech today. He spoke with a few people at Nissan and didn't get any new leads. I don't really know where we go from here beyond replacing the wiring harness. Even then we don't have a guarantee that it will fix the issue.
Old Jan 20, 2010 | 07:59 PM
  #39
SteveZ's Avatar
SteveZ
Back when you first posted this I thought "bad ECU" but figured they would test that and find it. Or, bad ground.
Confused. So when he ran wires straight to the suspect o2 sensor during operation the signal was in range expected? My '04 doesn't have the same O2 sensors as yours so it's mystery to me a little.
Obvious I know but have they checked thoroughly for any leaks in the exhaust side? Is it possible that the exhaust is letting in outside air upstream of the O2 sensor, which would throw it out of whack?
With the numerous episodes of rough running I'd pull the plugs and check them again, too.
One thing you can do with COBB AP that CONSULT cannot is log realtime data to file that can be dumped into Excel, i.e. MAF readings, record the variable timing every N seconds, almost every parameter that's useful but under road conditions. Then you dump the log file to a PC. I can't help but think that data would be helpful.
Also yes you can easily pass OBDII with a COBB tune, OEM basic map or not. The trick to clearing a code and passing is you then need to drive it long enough to store a code that says everything is cool. You cannot just clear the codes in the parking lot with your AP, drive it up for testing and pass, no way - someone was clever enough to close that loophole on most if not all OBDII cars.
Under warranty I'd be pushing the folks at Nissan to resolve this, they have to no matter what it takes, esp on an '06. The other thing to be sure of if you are on the cusp of losing the more comprehensive warranty (3/36?) that they log this as a continuing problem. What I am saying is don't get screwed by having it become a new problem out of warranty.
You can go to any dealer for warranty-related service, it may be time to try somewhere else.
When my G was throwing random misfire codes and it was close to emissions inspection time I was seriously pissed, the time to renew the reg was closing in and no sticker, no renewal. Once I found the VC leak problem, cleaned out the 5-6 years of crap in the TB, and replaced plugs I was pretty much good to go. Btw since I posted my dealer replaced the covers under warranty at 58k miles 59 months, dodged about $800+ in out of pocket repairs. Phew...
Good luck and post back with what you find, sorry to hear it's such a *****.
Old Jan 21, 2010 | 07:27 AM
  #40
tnk210's Avatar
tnk210
When he ran the separate wire it still showed being out of range.
The car is actually an '03, so it's well beyond the warranty. They have been great so far, it's just a mystery what's going on.
