Window Problems
Old Nov 21, 2009 | 01:13 PM
300plus50z's Avatar
300plus50z
Default Window Problems
I have a 2003 350z. For some reason the driver's side window, when put up using the automatic switch, it reaches the top of the window frame, stops then goes down to half way up. I have tried resetting the car by disconnecting the battery but no luck. Any suggestions? I want to try and avoid replacing the motor.
Old Nov 21, 2009 | 01:27 PM
NISMO_558's Avatar
NISMO_558
You may end up having to replace the window motor. 2003 Z's have the most problems with the window motor.
Old Nov 21, 2009 | 01:30 PM
1GR8350Z's Avatar
1GR8350Z
https://my350z.com/forum/maintenance...dow-motor.html
Please search next time
Old Nov 21, 2009 | 01:51 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
^^^^+1 there is a reset procedure and its on VO's thread.. It probably just needs to be reset (and you cant do that by unplugging battery)
Especially if your not having any issues with it dying or sputtering while the window is going up or down
here it is - check out the attachments
https://my350z.com/forum/5779726-post17.html
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
